Old 02-19-2004, 08:27 AM   #15
I was up on the roof of our trailer last week, installing a new Skyliner antenna, and I decided not to use my usual boards to distribute my weight. I played safe, and walked on or close to the rivets. Howver, I noticed that when my feet were by the awning cover, the vulkemed joint opened up. When I removed my weight, the joint closed up, and appeared perfect. This joint is clearly a potential source of leaks around the rivets, so I decided to repair it. Using a strip of Vulkem on top of the joint seemed a little crude, so I have covered the joint with a 20 foot strip of the high grade aluminum tape used for connecting industrial ducts. I will monitor it closely to see if it is a success. If not, I will use the vulkem. I recommend staying away from the awning tube when walking on the roof. I suspect I disturbed a sound joint. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 08-21-2005, 06:41 PM   #16
jaiman's Avatar
Images: 32
Just to clarify
Getting up on the roof of any Airstream trailer from 1969 on up is very easy with most 8 foot or better ladders.
Place the ladder against the "drip cap" of a side window, and go for it.
Walking on the roof "DOES NOT" require any special anything. Wear some type of non-slip shoes and that is all you need.
Many years ago, Airstream had a picture of a 30 foot trailer, with 20 (twenty) men standing on the roof, to demonstate the strength of the shell. They then put the trailer back through the water bath, and found zero leaks.
Walking on the roof is done by every Airstream mechanic that ever was. Obviously, you don't jump up and down, but you can walk any place on the roof you may want to, except for the end segments. Carpets, boards and the like are not necessary.
For safety reasons, DO NOT GET UP ON THE ROOF IF IT'S WET!!!!!!!! You will find the roof, when wet, becomes extremely slippery.
Airconditioner service, vent covers, TV antennas, sewer vent pipe covers, all require getting up on the roof. You will find that at "ANY" dealership, walking on the roof, is no big deal. It's done everyday.
Does this include Motor Homes?
jaiman is offline   Reply With Quote
Old 08-21-2005, 07:12 PM   #17
Craftsman
Guest
Posts: n/a
I remember when I took my first tour of the factory, there were acouple of guys working on a roof section and I asked if was strong enough to walk on. They said sure they do it all the time.
Old 08-22-2005, 06:38 PM   #18
Jaiman
All Airstream trailers and motorhomes, Argosy trailers and motorhomes, and Land Yacht trailers and motorhomes, are all built well enough for several people to walk on the roof "at the same time".
However, do not walk on any segments, as you will damage them immediately.
Old 08-22-2005, 06:45 PM   #19
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Coming to a theatre near you ....
Michael Flatley's AIRSTREAM RIVETDANCE!
cosmotini is offline   Reply With Quote
Old 08-22-2005, 08:19 PM   #20
jaiman's Avatar
Images: 32
Groan!
Thanks Andy. When you refer to "segments" are you referring to the lap joints where 2 pieces of Aluminum join together?
Old 08-22-2005, 08:26 PM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by jaiman
Groan!
Jaiman,
Segements are the curved ends they are very fragile. If you are walking on the main roof there should be no issues...just don't slip and fall
Aaron
WBCCI #XXXX AIR #2495
