Old 12-02-2011, 01:53 PM   #1
1981 31' Excella II
New Market , Alabama
Need CAD drawing of the roof contour
I was wondering if someone had a CAD or scale drawing of the roof contour. I am trying to design a scaffold to go on the roof so I can work up there more easily. Someone on the forums had a 3D model of an Airstream.
Perry
Old 12-02-2011, 02:43 PM   #2
heslinhotel's Avatar
1989 29' Excella
1974 Argosy 26
1999 25' Safari
Youngsville , North Carolina
When I have to work on the roof I use 2 2x6's on their edge running front to rear spanning at least 3 ribs with 2x4's screwed across the the top. I then place a piece of 1/2" ply on top to complete platform. Using screws makes it easy to remove.
heslinhotel is offline   Reply With Quote
Old 12-02-2011, 02:53 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Remember that the roof contours differ over the years. If you want something that actually sits snugly on the roof, yours would differ markedly from the later wide-body trailers, but if you're looking for something that would stand on the ground to either side and clear the trailer, building to the later contour would work for older trailers as well.
David
Old 12-02-2011, 03:09 PM   #4
dznf0g's Avatar
Oswego , Illinois
This is on the list for a winter project for me. Could you post some pics and maybe elaborate on dimensions? Did you bevel the 2x6 edges? Carpet or other material on roof contact points? etc.......
On a widebody, would vertical 2x4s work better?
-Rich-
Old 12-02-2011, 05:40 PM   #5
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I you take a look at the Airstream models in Google's Sketchup you'll find a few.
truckasaurus is offline   Reply With Quote
Old 12-02-2011, 06:30 PM   #6
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Check the construction rental places for scaffolding. I am getting them relatively cheap for my jobs and you can configure them to fit whatever you need ( like legos). might be an easy way to accomplish what you are trying to do!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 12-02-2011, 08:22 PM   #7
Central , Mississippi
or do like the rest of us...prop a ladder on the awning rail...climb up and stand on the rivet lines
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-02-2011, 08:24 PM   #8
dznf0g's Avatar
Oswego , Illinois
Yeah, if I only had room in suburbia....one day.....
-Rich-
Old 12-02-2011, 09:40 PM   #9
1981 31' Excella II
Ok Maybe Scaffolding was the wrong word. How about a platform that will allow me to work and move around up there without killing my knees, back, and torn ligament in my foot. I will work on a drawing and show everyone what I have in mind. I am going to have to replace the AC soon so I better get comfortable.
Perry
Old 12-02-2011, 09:47 PM   #10
dznf0g's Avatar
Oswego , Illinois
Perry
I know exactly what you mean, a platform which fits the curvature of the roof and is large enough to move around to relieve those joints without sticking some boney part through the soft aluminum between the ribs while trying to hoist an air conditioner around......or whatever.....
-Rich-
Old 12-02-2011, 10:25 PM   #11
Perry
Ya might be overthinkin' this...
I suspect you will spend more time riggin some sort of roof platform than is required to replace the AC unit.
On edit...you have probably already spent more time on this thread than is required to do the swap!
A couple of wire clips from inside, 4 bolts and off it comes. I probably spent spent less that :10 on the roof during my install.
http://www.airforums.com/forums/f205...tml#post839907
Old 12-02-2011, 10:57 PM   #12
Every dealers mechanics, as well as the factories, walk on any Airstream or Argosy roofs, every day.
I have been doing it for over 46 years, without ever having or causing any problems, and so have all my mechanics.
DO NOT however, walk forward or rearward of the awning rail. If you do, you will damage some segments.
To make a platform, is a waste of time, a waste of money, a waste of talent, and is totally unnecessary.
In spite of the holidays, just don't do a polka or any other kind of dance while on the roof.
Wear rubber soled shoes, and DO NOT ever attempt to get on the roof, if it's wet in any way.
Lean a ladder against a side window drip rail, thats cushioned with a towel.
Climb the ladder, grab ahold of the awning if one is there, and do whatever it is that you need to check or repair.
Old 12-03-2011, 09:19 AM   #13
1981 31' Excella II
Well Andy that may work fine for skinny folks. I am just looking for a way to be able to move around and stay comfortable. If I were still in my 30's and not weighing 260lbs with knee, foot, and back problems I would agree with you. I can and have gotten up there but it is not something I want to do for long periods of time.
Perry
Old 12-03-2011, 09:30 AM   #14
Perry
Perry.
Over 40 years ago, the Ohio factory had 30 adult men, all stand on the roof of a 30 foot Airstream, all at the same time, to show it's strength.
Result??
No damage.
Great advertising.
I understand your concern, however, our shop foreman weighs a little more than you do.
How many panels make the roof??? asmodeus Roof 2 08-28-2011 09:43 PM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 08:02 PM
Roof Vent Insect Screen Installation Guym General Repair Forum 2 05-06-2011 08:08 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 01:50 PM
