Old 12-03-2011, 08:57 AM   #15
CanoeStream's Avatar
St. Cloud , Minnesota
This thread discusses the same topic and has links to other discussions. Shari's photo in post 22 shows a viable option; you could do the same with rented scaffold. I might do something like that if I was installing an air conditioner. The factory Service Center lifts air conditioners to the roof with a forklift -- but the worker installing it is standing on the roof.
5 meter Langford Nahanni
Old 12-03-2011, 01:35 PM   #16
dznf0g's Avatar
Oswego , Illinois
My case for a platform is not for walking around. It's for kneeling and sitting when I have time consuming service to do, like removing sealer and resealing, Replacing skylights, etc.
I've walked around for the little quick jobs just fine by keeping my skinny feet on the rivet lines. I want to displace multiple pressure points of crawling around over a large area. Also, it's hard to keep my broad butt on the rivet lines!
-Rich-
Old 12-03-2011, 01:49 PM   #17
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The rivet line, you'll notice, is not mentioned by Andy. It's a non-starter.
Old 12-03-2011, 02:11 PM   #18
dznf0g's Avatar
Oswego , Illinois
Whatever....I just don't like being off the ribs and stringers.
-Rich-
Old 12-03-2011, 02:43 PM   #19
DFlores's Avatar
1968 22' Safari
Here is my solution for us inexperienced roof climbers. I bought a 9 step warehouse ladder that originally was used by Best Buy. I am now making a little cantilever (sp) platform to put my belly on as I work on top of my 68 safari, which is more rounded that the newer models. I first tried the ladder and 2x4, but it did not put me in a good position to step on top, maybe I'm just scared of falling off?
DFlores is offline   Reply With Quote
Old 12-03-2011, 02:48 PM   #20
2005 28' Safari
saline , Michigan
I have a piece of dense styrofoam about 2 x 4 ' that I lay up where I might be working. Its fairly comfortable when on a knee and is easy to handle.
Kosm1o is offline   Reply With Quote
Old 12-03-2011, 04:25 PM   #21
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
I was so pleased when they replaced both my roof airs: DUAL FORKLIFTS!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-03-2011, 05:13 PM   #22
1981 31' Excella II
New Market , Alabama
This is what I have in mind. I could add another support in the center but I don't think it is necessary. I could also make some sort of hook that attaches to the canopy cover that would keep it in possition no matter where I was on the platform.
Perry
Here is what I have in mind.
Old 12-04-2011, 06:46 AM   #23
dznf0g's Avatar
Oswego , Illinois
I was thinking narrower, across and wider longitudinal with the trailer.
-Rich-
Old 12-04-2011, 06:58 AM   #24
1981 31' Excella II
Well if you make it wider it won't fit between all the vents and other stuff that is up there in the way. Also the width makes it less likely to slide off the sides.
Perry
Old 12-04-2011, 06:59 AM   #25
2005 28' Safari
saline , Michigan
That is going to be heavy and hard to get up there without some assistance. And you stand a chance to bang up your trailer in the process. IMO
Old 12-04-2011, 07:04 AM   #26
1981 31' Excella II
Yeah that is why it is in the concept stage. It could be lightened by using more plywood and OSB.
Perry
Old 12-04-2011, 11:00 AM   #27
dznf0g's Avatar
Oswego , Illinois
The more I think about it, I may just go with 3/4" plywood with an anti slip surface bonded to the bottom, large enough to always span 2 ribs or stringers.. Make several of these for the various odd dimensional spaces on the roof. So, for example, there may be 2 to 4 of these around...say a vent, for example during a reseal or replacement. All I'm really interested in is displacing point loads of knees and elbows, hips and butt over a larger area so I don't dent between the structural members. Doesn't matter to me if they rock a little, as long as they are non slip.
-Rich-
Old 12-04-2011, 02:13 PM   #28
1981 31' Excella II
I have been using a 3/4" x 10" wide shelf board about 4ft long. You can get stair treads that are even thicker that would work well.
Perry
How many panels make the roof??? asmodeus Roof 2 08-28-2011 08:43 PM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 07:02 PM
Roof Vent Insect Screen Installation Guym General Repair Forum 2 05-06-2011 07:08 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
