Old 08-29-2015, 09:03 AM   #1
1981 31' Excella II
New Market , Alabama
Maxxair Vent cover install on OEM vent
I am trying to install one of these Maxxair Vent covers on my 81. The OEM vent has round corners and the mounting brackets don't have any place to go if I use the mounting holes in the vent flange. I guess I am going to have to mount the brackets farther inboard where they will be on the flat portion of the vent housing. I could just drill new holes in the plastic flange (cracks) or make a bar that spans the reinforced mounting points. I was wondering if anyone had done something similar and how that worked.
Perry
Old 08-29-2015, 09:19 AM   #2
KYAirstream's Avatar
Northeastern , Kentucky
I ran into the same issue a couple months ago when I installed mine. I attached the brackets toward the rear of the vent covers using the included bolts. The brackets on the front end I (dare I say) attached directly to the roof. I also used a good deal of polyurethane sealant so it oozed out on all sides of the bracket when tightened down. Since these holes are sealed so well AND are also under the vent cover, I don't expect any issues.
However, if I were to do it again I might use solely the sealant Lewster recommends for attaching solar panels.
KYAirstream is offline   Reply With Quote
Maxxair Standard Cover Over Fantastic Fan Cannonball Roof Vents, Skylights & Fans 32 06-04-2015 08:17 AM
MaxxAir Vent Cover for 2014 Sport 22FB Cannonball Roof Vents, Skylights & Fans 2 03-13-2014 12:04 AM
MaxxAir Vent Cover ... color? Soyboy Roof Vents, Skylights & Fans 26 03-26-2011 03:43 PM
MaxxAir II Vent Cover over Fantastic Fan successful installation longdog Roof Vents, Skylights & Fans 2 12-02-2009 07:01 AM
Maxxair vent covers BillTex Roof Vents, Skylights & Fans 3 04-29-2008 08:09 AM
