Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 11-21-2009, 01:25 PM   #1
Profile:  1964 24' Tradewind
printer , Kentucky
large vent
there are 3 vents in my 1964 airstream. the large on is about 14X26 in size. someone has put a plywood board over it. I called a dealer in Calf. he suggested that I remove, clean and replace it with piece of plexiglassis. will this really work?
mitsy is offline   Reply With Quote
Old 11-21-2009, 01:50 PM   #2
silverleeper's Avatar
Profile:  1967 22' Safari
1960 Caravel
Edmonds , Washington
Airstream Registry
Hi mitsy, You probably can just put lexan over that spot. If you want to know what is suppose to be there look here. Airstream Astradome. Some times you can find the lifters on e-bay or craigs list or air classifieds. This is an example of the lifters. Restoration Topics. Standard vent but you'll get the idea. Inland RV sells replacement lifters if you can't find the originals.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-21-2009, 04:18 PM   #3
Profile:  Corona , California
Replacement astrodomes are available, in milk white, solar gray and fiberglass.
The fiberglass unit, unfortunately, do not allow any light to pass through the.
The white and solar gray, both let in adequate lighting from the sun.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-21-2009, 09:34 PM   #4
Profile:  1977 31' Sovereign
McHenry , Illinois
The lifters are the hard to get or expensive part. Per the forum rules Andy is not allowed to sell things on the forum so you should call him Monday morning to get the prices. I replaced my broken solar dome with flat corrugated Lexan used for Green houses 20 years ago. It is still working perfectly but does not look like the original dome. You can buy a piece at Home Depot for $10.
Old 11-22-2009, 01:02 AM   #5
printer , Kentucky
do you have a pic or a way to show me what you used? if it has lasted that long without leaking, it seems the way to go for the money. I have so much to do to the camper that I have to at least try to make it water tight till I can come up with money for the expensive parts. Thanks!
Old 11-22-2009, 03:55 AM   #6
McHenry , Illinois
I think I have posted these before but to save you the trouble of using the search function, I will attach them here. You still need the lifters unless you decide to do the Wally Byam thing and hinge it. There are pictures of him poking his head out of his personal unit. He may have used it to gain access to the top. The aluminum outer frame is necessary to prevent the rain coming in from the side. The corrugated Lexan gives a defused light as well as improving insulation. It is produced by having pins in the extruder die and results in tubular air channels in the finished product.
ID:	91373   Click image for larger version
Too Large? pixiehat Towing, Tow Vehicles & Hitches 45 03-13-2009 10:36 AM
What do you tow your large (25'+) AS with? BillTex Tow Vehicles 41 03-01-2008 11:56 AM
Looking for a large gutted A/S kdenault Our Community 5 05-11-2006 11:44 AM
A Large Family Janet's Husband Our Community 15 02-25-2004 09:53 AM
Small or Large Penquin GoldFever Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-16-2003 10:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
