Old 10-15-2015, 07:36 AM   #29
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Final coat, #3 applied yesterday by our sons. Camping this afternoon!
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-15-2015, 09:16 AM   #30
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Looking at the 2nd photo I see rough areas. Did the paint set up too fast? How did you apply it, brush or roller? Did you reseal all vents before painting?
Kelvin
Old 10-15-2015, 09:57 AM   #31
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
That is a real improvement Channing!
Looks great!
Brevi tempore!
Old 10-15-2015, 11:54 AM   #32
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Kelvin
Yes, Kelvin, my adult sons showed up to help dear ole Poppa. They put strips of reinforcement fabric rather than my requested solid run fore/aft. I was glad
For the help.. As they neared the bow, they got "better"...but the stuff is pretty thick.
I brush applied Enviro-patch(EP) to all roof penetrations after cleaning and sealing everything. A layer of EP, fabric, more EP. SMOOTH out well. Notice the difference between the curb side rear rough patch and the skylights... I used EP only around plumbing and fridge vent so that I can remove and repair as needed without major risk to underlying fabric.
After proper cure of 48 hours on the EP, I applied the "primer" in the morning and afternoon. That evening (double the cure/recoat time), I applied first coat of Bus-Kote. Followed by an overnight cure then two more coats curing each overnight to next afternoon. We have had record high temps in Texas during this time.. Helped since I had no cover. I "cut-in" around all roof penetrations with brush then used 6" x3/8" nap roller on a long pole to apply the primer and Bus-Kote. Cleanup with water.... But once "cured".. You have to scrape it off.
Time from start cleaning, repair antenna, reseal, scrub roof with scotchbrite pad and rinse very well, on our 34' was about a step a day. Brushing final coats about 50 minutes each. Not including setup/cleanup.
Today it is already over 92 degrees and inside is a balmy 81.5.. Only the vents open... I am sure as the sun hits broadside temps will climb.
Channing
WBCCI# 30676
Old 10-18-2015, 11:03 PM   #33
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Update..
Following this weekend where temps were in the 90s in the day we found the interior roof was same temp as the air inside. The walls were 8-20 degrees warmer! So, our roof coating has made a significant improvement. And it is much quieter!!! Night and day the ACs would cycle on and off... NEVER did that at these temps before!
Will see...
Channing
WBCCI# 30676
Old 11-12-2015, 05:22 AM   #34
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Nice! Another Item on my 'to do' list. It will be nice when I start putting stuff from the 'to do' list onto the 'Ta Da!' list.
Philip
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Rust Coatings-Help? budal General Repair Forum 7 06-07-2009 05:55 PM
Seal Tech for finding water leaks? Raptorrider2001 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-18-2005 07:05 PM
Thur 11/27 on Tech Live Moonshot Airstream "In the News" 3 11-29-2003 12:54 AM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 02:08 PM
