Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 08-04-2011, 09:02 AM   #81
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by Gator113 View Post
Plan B: I'll get a younger and more agile friend up here to give me a hand... buy him beer and put on a bbq. I'll warn him that if he screws up my Airstream, I'll use my backhoe to bury him alive out behind the barn. ;>)
Cheers,
Dan
You could make a movie out of it.
Gene
Old 08-05-2011, 06:54 AM   #82
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
This worked great for me. Walk on - walk off and all tools, drinks, etc are handy
Darkspeed is offline   Reply With Quote
Old 05-04-2013, 11:00 PM   #83
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I have a 2008 Classic that has the full length awnings on both sides. Is it OK to to rest a ladder against the awnings aluminum cover? I want to get up to remove the AC cover.
Kelvin
Old 05-05-2013, 06:02 AM   #84
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
It is possible to mount the roof that way. I don't due to physical issues at this time. But my grown sons have. Ours is 34' 1999.
Wear nonskid sole shoes. Have someone hold ladder or properly secure.
Walk on rivets where strong. Use wood to spread the load so you don't center too much force.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-05-2013, 06:59 AM   #85
Crusty's Avatar
1992 34' Excella
Darkspeed, that picture is so reminiscent of my installation of a heat pump. I used one of those ladders with hinged sections to form a leaning scaffold similar to what you've done with the 2x4's and a simple block and tackle hanging from a tree to get the unit onto the scaffold where it could be slid over to the trailer roof.
Great minds think alike wouldn't you agree!
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 06-03-2013, 02:31 PM   #86
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Here's the best method that I've found for getting on and off of the roof safely using an extension ladder.
The picnic table and bench make a stable platform for things to be handed up to the roof safely (as long as they are not too heavy).
I tie the bottom of the ladder to shock absorber mounting brackets and I tie each side of the ladder to the main awning brackets. It's important to note that the ladder feet are far enough away from the trailer that the ladder has a reasonable pitch so that I can have my weight/center of gravity over the top of the awning and trailer roof. Also note that since my driveway isn't level, I have shimmed the lowest foot of the ladder with a small piece of plywood.
Steve
Steve Bryant is offline   Reply With Quote
Old 06-03-2013, 04:35 PM   #87
Crusty's Avatar
1992 34' Excella
Imagine another ladder on the opposite side of the trailer and a 2x12 spanning across from ladder to ladder and you have my first scaffold. I don't set the legs anywhere near that far out though even with them tied together.
Having said that, these days I just lean a ladder against the side and go on up. When I get there I always walk on the rivet lines with no problems whatsoever. A 5 gal plastic bucket with a rope tied to the handle is handy for upping and downing stuff.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 06-04-2013, 09:39 AM   #88
2010 27' FB Classic
N/A , Texas
A rule of thumb I use . Set the ladder feet about one third the distance out at the bottom compared to the height of the ladder.
I use that for any project that I need to use a ladder. The tie off is a great idea for a little more safety.
On my wish list is a scaffold w/wheels.
Old 06-04-2013, 02:42 PM   #89
1991 34' Limited
Wichita , Kansas
Normally, I think that the treads on the rungs of the ladder should be about level and you will have a good setback distance for the ladder base. I've used more and less distance than that depending on circumstances. The reason that I'm using such an extreme setback distance to get on the roof of my trailer is so that I don't have to swing/place my weight over the ground below in an awkward manner. This way, I can simply step off or on the ladder which is over the roof a significant amount.
As an aside, I have a friend who became a paraplegic in his fifties due to a tree trimming accident. I'm also a former flight instructor and have worked in aviation most of my adult life. All of this makes me err on the side of caution. Another thing is that I've used up all of my nine allotted lives in the past.
Steve
Old 06-04-2013, 02:53 PM   #90
Master of Universe
Gene's Avatar
Steve
"All"? That means you are dead. I knew that zombies were everywhere, but this is the first one on the Forum (that I know of). If you fall off the ladder, I guess it won't hurt. I guess being a zombie makes it easier to climb to the top of our trailer—I'll have to look into that. It may cure my arthritis.
Gene
Gene
Old 06-04-2013, 11:07 PM   #91
1991 34' Limited
Wichita , Kansas
Gene,
Actually, zombies don't even have to worry about arthritis. It's one of the fringe benefits!!!
On second thought, let's say that if I were a cat I would have used over half of my nine lives. That's a more accurate statement. Thanks for calling my hand on the nine lives bit!!
Steve
Old 03-20-2014, 04:40 AM   #92
Coaster's Avatar
2020 16' Nest
Saint Augustine , Florida
I didn't try to get on the roof.But this baker scaffold worked great.Click image for larger version
Name:	ImageUploadedByAirstream Forums1395311997.561447.jpg
ID:	207885Click image for larger version
Name:	ImageUploadedByAirstream Forums1395312047.540306.jpg
Coaster is offline   Reply With Quote
Old 03-25-2014, 10:58 AM   #93
Gaël's Avatar
1960 26' Overlander
Wervicq-Sud , FRANCE
Images: 12
Originally Posted by Astroboy View Post
When on the roof, you want to keep your feet on the ribs: try to discern the locations by looking at rivet lines...
Really ? We can walk on the roof ?
I would be very afraid...
I'm looking for a solution to access on the roof to made work on this, polish it etc...
And this one :
Gaël is offline   Reply With Quote
Old 03-25-2014, 01:31 PM   #94
Splitrock's Avatar
Sioux Falls , South Dakota
For polishing, I needed to be up close and personal. I did most by using two step ladders and a plank between. Getting on the roof, I used two scaffolds and step ladders to climb the scaffold.
Old 03-25-2014, 02:14 PM   #95
2010 27' FB Classic
N/A , Texas
Originally Posted by Coaster View Post
I didn't try to get on the roof.But this baker scaffold worked great.Attachment 207885Attachment 207887
That's the same style scaffolding I ended up buying. I bought the outriggers (to prevent tipping) and wheels too.
I have several future projects that will require me to get high enough to work on the roof of the trailer.
It looks like the scaffolding will come in handy for a lot of around the house projects too.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
Old 03-26-2014, 03:49 AM   #96
Gaël's Avatar
1960 26' Overlander
Images: 12
Ok, yes, thank you for your replies, perhaps I have to buy 2 scaffolding style and install between each a wood plank... it's an economical solution no ?
Old 03-26-2014, 12:39 PM   #97
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Try swimming pool noodles. Slip them on to each verticle ladder support and tape them to secure them in place. Then when you lean the ladder against the awning, it won't scratch the AS.
tsunami is offline   Reply With Quote
Old 03-28-2014, 07:14 PM   #98
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
The scaffolds are the best way with ladders run across the trailer from scaffold to scaffold, secure them to the scaffold to prevent movement, you can cut a piece of plywood a little wider than the ladder and secure it to the ladder. This gives you movement on each end with the space in between for doing the work.
No touching the trailer, the whole system can be easily moved with the help of another person the full length of the trailer.
Scaffolds can be found pretty cheap right now mostly at pawn shops.
Sarge
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline   Reply With Quote
Old 03-28-2014, 07:17 PM   #99
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
And this one :
This can be a little unstable and have a tendency to tip sideways, this is why it says only use on level concrete or blacktop and do not climb off the tops.
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
roof khaled Roof 7 12-10-2008 01:22 AM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
