Old 02-06-2015, 07:41 PM   #1
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
How much is too much?
I am in NJ, at what point do I clear the snow off the roof of the Bambi? What do large dealers in snowy areas do? Go and clear roofs off every time it snows? i have about 20" in middle of roof because I cant reach it the way I parked for the winter. Ideas anyone?
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 02-06-2015, 07:44 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, turn the furnace on.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-06-2015, 07:54 PM   #3
Sbb
begorragirl
Sbb's Avatar
I tried that, but after snow we had a couple ice storms so it is really thick ice up there. On the plus side inside was very toasty warm, not very attractive with all cabinets open and little dryer sheets all over in efforts to deter any possible mice.
2010 Funfinder
2005 T@B
Old 02-06-2015, 07:58 PM   #4
1974 Argosy 20
Kooskia , Idaho
The roof will hold up a lot more snow than you have now. You can do more damage trying to remove it than leaving it alone. No need to do anything.
Old 02-06-2015, 09:12 PM   #5
Salem , Oregon
Images: 18
[QUOTE=Sbb;1577834]I tried that, but after snow we had a couple ice storms so it is really thick ice up there. On the plus side inside was very toasty warm, not very attractive with all cabinets open and little dryer sheets all over in efforts to deter any possible mice.[/QUOTE]
Hi, Fill or block off the front frame rails; I put stainless steel wool in mine and filled it with expanding foam. I use the dryer sheets too, but if really concerned, I would set some traps.
2005 Safari 25-B
Old 02-07-2015, 09:35 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Too dangerous for us....it's slippery enough on dry aluminum.
Plus how to get it off?, push it, sweep it, blow it or let it melt.
I choose let it melt.
Twelve years of WNY Winters no damage, no problems.
Nov, 17-21 2014 80".
Old 02-07-2015, 10:03 AM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I would not worry about the weight of any snow on the roof, remember that a 200 lbs person can stand on the roof with all the weight on what amounts to less than two square feet (note, this observation does not imply that you can have 100 lbs per SF over the entire roof and still be OK, but getting a snow load that weighs more than a few pounds per square foot of roof area would be quite a feat.) But, you should be concerned about where all the water will go when it starts to melt. One obvious point of vulnerability would be the roof vent for the fridge, another would be the AC unit(s.) You'll want to make sure that the snow melt has an easy way to get off the roof and to the ground as quickly as possible without getting diverted into an area that isn't intended to be flooded such as the two previous examples.
Bob Martel
WBCCI# 5766
Old 02-07-2015, 10:49 AM   #8
oldfulltimer's Avatar
1993 34' Excella
Randolph , Vermont
Holed up here in central Vermont, there is presently about 18" of snow on my 34' Airstream. However, I have 300 watts of solar panels on the roof and use a snow rake to keep them cleared off so the batteries remained charged. The snow rake with one extension works perfectly for pulling the snow off the panels and I've never had a problem leaving the remainder covered with snow.
On occasion, we've pulled out in the winter time meaning that the entire roof has to be cleared so I get on top and carefully shovel the snow off except for a couple of inches which then gets brushed off with a broom. Roof has to be cleared when towing so snow won't hit other vehicles while going down the road.
oldfulltimer is offline   Reply With Quote
Old 02-07-2015, 11:01 AM   #9
2011 23' International
clovis , California
As always, I agree strongly with Bob Cross. Getting that stuff off would be a dangerous project. As an orthopedic surgeon, I see lots of people who fall off ladders, even in dry conditions. Any damage to the airstream would be minor / cheap compared to fall, fracture, ER, surgery, rehab etc.
Of course, I am a little biased. No one comes to the surgeon and says "I climbed a ladder yesterday, cleaned the snow off my airstream, and didn't fall off".
jgerardi is offline   Reply With Quote
Old 02-07-2015, 12:20 PM   #10
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
However, if your trailer currently doesn't have interior walls, I would be careful how much snow I let build up. Wasaga Chris found that out the hard way last year when his trailer collapsed in the center....
Kay
Old 02-07-2015, 12:26 PM   #11
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
We miss all the fun down here in the south! Dang it! I think snow piled up on top of The LoveStream (tm) would kind of freak me out too... I'd have to get that stuff off. Then, I could pay a visit to an orthopedic surgeon... I'm surprised he's not encouraging this more.
-Red, suffering in the upper 60's...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-07-2015, 12:27 PM   #12
mefly2's Avatar
2015 25' FB Eddie Bauer
Extension pole on a broom head ... around here, the snow gets very heavy.
Old 02-07-2015, 12:31 PM   #13
2018 33' Classic
Newport , Pennsylvania
snow rake and a step ladder
EarlM is offline   Reply With Quote
Old 02-07-2015, 04:05 PM   #14
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Taxi it to the nearest airport and let them de- Ice it for you. Seat backs and tray tables in the upright position please.......
If you are concerned that damage will occur prior to the next thaw, You could use a 50/50 methanol / water mix (exact same stuff used for windshield washer fluid) and with a garden sprayer get the snow to melt enough to where a snow rake would work.
NavyCorpsman is offline   Reply With Quote
how much wind is too much? funkill Off Topic Forum 19 08-21-2009 11:58 PM
how much wind is too much Barry Parkof Awnings 15 04-04-2009 12:19 PM
How much is too much, or too little - 1962 Globetrotter? gduffydc 1960 - 1964 Globetrotter 3 01-07-2009 02:39 PM
How much damage is too much? kaulike Ribs, Skins & Rivets 8 01-20-2007 01:10 AM
Carbon Monoxide: How much is too much? Lotek General Appliance Topics 3 01-08-2005 06:06 AM
