Old 03-12-2006, 10:20 PM   #15
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
It has to be difficult to watch the active weather approach with concerns for the Airstreams. We saw a unit at International that had a hand hammered look to it and surmised that hail was at fault. Can hail damage pierce the skin and is that something that can be fixed? I read somewhere here in a post that small dings may pop back out after a season or two with expanding and contracting. Has anyone been through hail and the AS not suffer?
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 03-12-2006, 11:30 PM   #16
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
We're under tornado, storm warnings till 4am also. We are getting some heavy downpours as I type this. Luckily, the Twinkinator is stored inside currently.
I have heard that small damage may look better than after the initial hit after the hot/cold temp changes, but I doubt it would ever be the same. It can be fixed, but the current methods I know of are either skin replacement or an overlay of skin on top of the damaged skin. Neither sound really good to me.
Old 03-13-2006, 01:12 AM   #17
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Just peeking out--finally looks calm with nothing developing in Kansas to blast us here in Missouri. We had three distinct storms that produced hail and tornadoes. Pretty busy day.
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-13-2006, 04:47 AM   #18
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
During the Fargo International some years ago, dozens of trailers were hammered with 1" and larger hail. They resembled oblong silver golf balls. Many were totalled, and the owners bought them back for a song. You could easily spot them going down the road. They were actually became known as "Fargo trailers". I haven't seen one in a long time. I suspect that after a number of years of freezing and heating that most of them have recovered at least to the point that they're not obviously hail victims any more.
Roger
Old 03-13-2006, 07:13 AM   #19
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Well we dodged the storms last night. My weather radio seemed to be going off at least once an hour as the storms from midnight on rolled through the state. The local weather guys said some of these super cells showed up at 8 AM in Kansas on Sunday and were into Indiana after midnight last night. What's unbelievable is that the same super cell kept skipping tornadoes across Kansas, Missouri and Illinois. They said that this was an incredible series of storms. Normally a storm cell will deteriorate over time and distance. If you were a student of meteorology, this weekend provided a lot of fodder for class discussion this week.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-13-2006, 07:20 AM   #20
eljay's Avatar
1968 24' Tradewind
Jack, I was thinking of you as I watched this things develop and worsen from our side of the state to yours. I wonder how maxandgeorgia fared.
I just checked Icky. Glad to report no hail damage.
Eljay
Old 03-13-2006, 08:18 AM   #21
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Thanks for thinking about us, Laura. We got through the night okay, like Jack, but storms were popping up all around us. We had one brief hail spell, but it was over quickly here-incredible and ongoing wind and lightening, and like Jack, our weather alert kept waking us all ngiht long. I'm just glad we have it since we are pretty far out from a community siren. The morning news revealed some tragic situations. We were very lucky.
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 03-13-2006, 11:23 AM   #22
jcanavera's Avatar
Fenton , Missouri
Images: 143
Radio weather alerts
This really brings up the idea of carrying a weather radio when out which is reallly important. The one I carry with me uses the SAME technology which allows you to put in county codes that will only allow alerts in the coded counties you load in.
Normally when I plan a trip, I'll use my Good Sam directory to find the county of each campground that I'll be staying in. Via the NOAA Internet site you can then find the county codes that match the county names.
Finally and dependent upon your weather radio, you can load the codes. In my case my radio holds up to six codes and can montor all six at the same time. This is important to me since I may stay at different sites each day, and don't want to bother having to activate or change out a code. The only thing I do is turn the radio on, find the local channel that provides the best reception, and then switch it to standby.
The cost of my radio was $35 on ebay and it runs on batteries or 110 volts.
Here's a picture of mine.
http://www2.oregonscientific.com/sho...cid=74&pid=278
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-13-2006, 11:42 AM   #23
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Glad to hear that all of you faired well thru the night, was thinking and praying for you all last night.
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 03-13-2006, 12:24 PM   #24
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Oh HAIL!
To a southerner "HAIL" is the ultimate abode of General William T. Sherman.
"Rye-cheer" is one's present location. (Right here...)
"ya'all" is singular... the correct plural is "all ya'all".
Anyway, I have actually seen someone use one of those little dent pullers on golf ball hit ding on the side of an Airstream. Popped it right out. Now if you have 500 little dings, you might want to park it in the sun and wait patiently for expansion and contraction to do it's thing.
Anyway, glad you made it through the night and are dry. Good luck with replacing your vents... And I would say to upgrade to at least one fan. They move a lot of air and make it very pleasant to be inside.
Tin Lizzie
Old 03-13-2006, 12:52 PM   #25
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Ya know, it's the strangest thing....We haven't had hail 'round these here parts in years 'till we drug that 'luminum bueaty home about 18 months ago. Since then, we've had three hail storms. Luckily, nothing bigger than dime sized stuff. No damage, thank goodness.
Good to hear everybody's o.k. It is springtime, so I supopose we've more of this to look forward to. 80 degrees in Atlanta right now and that stuff y'all had to deal with yesterday is headed our way by midnight.
www.nesa.org
Air No. 6427
Old 03-13-2006, 01:36 PM   #26
1995 30' Limited
Ashland , Missouri
Our weather alert was given us as a Christmas gift by our son/family. I do not know the price, but it is by Midland, called All Hazards Alert Weather Radio, includes additional features such as an AMFM alarm clock with snooze, a calendar display of day, month, and year (good for me since I haven't kept a calendar since retirement last May!), color coded alert lights for 3 levels, a telescopic antenna for reception within 50 miles of an active NWS transmitter, and multiple kinds of warnings that can be issued. Like Jack says above, you code in the counties that concern you so that you can reload as you travel across the country. Another good feature is that it has accessory jacks for a plug in optional stobe light or pillow vibrator for the deaf or hard of hearing and also an external antenna jack for improved reception for inside concrete or metal buildings (Airstreams?), and has emergency battery back up (4 AA's). We are well pleased with its performance after last night. ~G
maxandgeorgia
WDCU
Old 03-14-2006, 09:31 AM   #27
jimmieanna's Avatar
1974 31' Excella 500
charlottesville , Virginia
Just an little update here in the Springtime in the Ozarks! Sunday night here we had tornado's popping up all around us. The owners of the RV Park came knocking on my door at 10:30 pm to tell me that a tornado was heading this way(I had been in bed with bad sinus++ all evening) and invited me to come into their shelter. Of course I did, and waited until the storm passed. While I was waiting the electricity got knocked out, and stayed off until @ 6am that morning. I came home about 11:15pm, and the wind blew hard all night. My tarp got blown off, but no rain got inside. I had to go to work yesterday, but I told my boss I needed today off to get up on the top of RV and measure for vents and cover them temporarily, the tarp is just too much, keeps blowing off. It was a good emergency fix, definately not a permanent solution. (smiling)
I am waiting for the sun to warm things up a bit before I climb on top. I have some materials to use to cover vents that should hold until I have more time to order vents. This head conjestion is not helping matters, but I still have to keep going, rain forecast again this weekend. Oh those March Winds and April Showers bring us those beautiful springtime flowers.
jimmieanna is offline   Reply With Quote
Old 03-14-2006, 09:39 AM   #28
No Climb temporary fix
You might be able to do a temp fix from the inside. Get a plywood square that will fit through the hole diagonally, then turn it 45 degrees and it should cover the vent. To secure it, just staple a loop of rope to the bottom, run a length of board or dowel rod through the loop and twist until it tightens to your inside roof. Cheap, quick and no roof climbing.
Paula
'59 Trade Wind flyfshr 1959-69 Tradewind 196 03-10-2013 09:42 PM
Airstream Chat! Tutorial & Focus group tonight! Andy R Our Community 11 08-16-2005 08:09 PM
ultra violet damage bhsl8 Tires 10 11-10-2002 03:03 PM
repair 1978 Tradewind Pam1 General Repair Forum 1 06-21-2002 08:28 PM
Hail Damage jcanavera Our Community 4 03-30-2002 09:24 AM
