Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 06-29-2007, 09:55 AM   #1
jpancini
jpancini's Avatar
Profile:  1966 26' Overlander
Lowell , Indiana
Getting the top
Hi
I am beginning the cleaning and noting of problem spots that will need attention on my 66 overlander. I see the previous owner had used a clear caulk around the furnaace vent and looks like same on the roof vents. There seems to be caulking/sealant loose around the top vents. Not being of great mechanical ability, how or what is the best way to clean and make repairs to the top of the trailer without denting the top?
John
jpancini is offline   Reply With Quote
Old 06-29-2007, 12:37 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Place a ladder against the awning tube, if you don't have an awning, wrap towels around the part of the ladder that will touch the body of your trailer. Climb the ladder, and onto the roof, being careful to place your weight on the rivet lines.
Change is inevitable, except from a vending machine
AIR#2611
Old 06-29-2007, 01:42 PM   #3
Streamin 65
Streamin 65's Avatar
Profile:  1965 26' Overlander
Marysville , Ohio
Images: 14
Getting topside
I use an articulated ladder, similiar to this : 16' Aluminum Multi-Purpose Articulated Ladder, Type I Only it's a 12' and I bought it from local Ace. I make the ladder into a big "L" shape and turn it upside down putting the small part of the "L" on the roof on a rib. Before putting it on the roof, I tie a bunch of towels around the part of the ladder that will lay on the roof to spread out the weight and keep it from scratching the aluminum. --dave
Streamin 65 is offline   Reply With Quote
Old 06-30-2007, 04:14 PM   #4
rvs68
Profile:  1968 28' Ambassador
dallas , Texas
i purchased an "industrial" shelve from the local "do it yourself" store($120). 18" wide by 72" long and 72" tall. i placed the metal side supports in as if it were a storage shelf but placed all the wooden shelves on top for support. by using a couple of c-clamps on the shelves, it kept them from sliding off. 2x6 were put under the legs (each side) and lag screwed in place which gave me front to back stability. This was a bit wobbly but i managed to use it without any trouble.
rvs68 is offline   Reply With Quote
Old 06-30-2007, 05:42 PM   #5
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs , Florida
Red face Getting on top
I thought this thread was about sex - I'm outa here - -
Pop Rivet is offline   Reply With Quote
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 09:19 PM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 09:26 PM
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 2 10-16-2002 08:39 PM
On top of Mt. Kiamichi Pahaska On The Road... 4 09-09-2002 11:42 AM
carry a pod on top?? pebblepoint Roof 1 06-28-2002 09:05 PM
