Old 07-03-2011, 09:39 AM   #1
Rob&Julie's Avatar
1988 32' Excella
Bonny River , New Brunswick
Images: 16
EYE OPENER! Oh, and the refrigerator vent is finally gone, too.
Well it only took me 3 years but I finally replaced the leaky propane fridge vent with a nice clean patch.
It took a lot longer than I thought...I reno'd our house and I was thinking that the AS was more or less a big "room" and the timeframe would be similar to what I did in the house for a single room. Man, was I wrong! It took me almost all day to do a simple patch....I hope the learning curve will speed things up! Also, my power shears died; that was a pain. The longest part was getting the three layers of "gunk" off the roof. Not sure what the PO used but it was tough stuff! Too bad it wasn't waterproof!
I started with plastic scrappers and "goo be gone"....that was a waste of time. Then I moved to varsol that was ok for the thin areas but was still painfully slow. Then I thought, "Wait a second, this is going to be UNDERNEATH the patch!" So, I broke out the metal scrapers, pocket knife, and a flat head screwdriver. That took the thick areas off but then I had to contend with the residue.....I resorted to an orbital sander.
Then came the riveting....I will add that this was first attempt at riveting and shaving....
There was no way to match up the old holes so I made the patch a bit larger so I could drill new holes and seal all the others. So with the patch cut out.....with hand shears and a grinder so don't look at it too closely. I measured and marked the location, placed the patch, checked it twice, and drilled a hole on either end, cleco'd it in and proceeded with the drilling and clecoing of the remaining holes. The next thing was another learning experience....I removed the patch and vulkem'd each hole, old and new, as well as adding a double row of sealant along the top just in case....I do this when I shingle roofs as well. Well, when I went to cleco the patch back on I realized my error. The cleco's were going to get messy! It took me another hour to get them all clean. It would have been faster just to dip each rivet and it ended up I had too anyway because the cleco took most of the vulkem with it when I took it out.
I had grand thoughts that I would add this to the forum for others to see so I took progression pic's. I don't think I'll be adding the photo's though the rivet placement is a little sloppy. I thought it was good when I was up there but after I took a look at the photo's....not very straight or even. I lovingly refer to these small errors as "A#$#@le detector's". For example: Guy at Campground says, "Nice AS! but I noticed your rivets are uneven and not straight!" I am am instantly aware that he is an "A#$#@le
The good thing is that it's on top and the only people who will see it are ferry operators on a raised bridge and pilots of low flying aircraft.
On another note if anyone needs a used propane fridge vent I have one and it's free to a good home.
Rob&Julie is offline   Reply With Quote
Old 07-03-2011, 10:52 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Ah, you're one of THOSE people. I live with one. If the holes aren't perfect, something looks slightly messy, etc, etc, it's not good enough even in a place that NO ONE WILL SEE. No one will see it, and we won't complain about your "hole placement". It works and it's perfect! Just keep repeating that to yourself, and eventually you'll believe it too. I'm still working on mine.
Kay
Old 07-03-2011, 06:18 PM   #3
Rob&Julie's Avatar
1988 32' Excella
Images: 16
Thanks Kay, I may have to add that as my new mantra ;-) I admit I am one of "those" people with certain things... for example the AS, the new zero turn lawn mower (absolutely love that thing), and my hunting implements. Things that I am not one of those people with....my office, the basement (its a tad cluttered), and the kids toys (i pick them up once at the end of the day) ;-)
I did try to upload some pic's but it wasn't working for me tonight.
Old 07-03-2011, 07:52 PM   #4
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
Yes, I hear you on this project. My PO sealed up the hole from the missing plastic refrigerator vent cover with newspaper, spray foam, and "Koolseal". I worked for days getting this crap off the roof with mineral spirits and hardwood scrapers. I put on an aluminum Airstream vent cover. Looks good now.
Bill AKA Cosmos.
cosmos is offline   Reply With Quote
Old 07-04-2011, 10:11 AM   #5
Minno's Avatar
1972 31' Sovereign
Boy, you really ARE like my hubby! His office is so cluttered I'm amazed he can find anything. I do confess I get perfectionist about my quilts sometimes - I know where the flaws are even if no one else would ever notice them. l just keep in mind that the Amish women put a deliberate flaw in all of their quilts because only God is perfect. I don't generally have to worry about that... Probaby works on Airstreams too.
Kay
