Old 08-02-2015, 12:17 PM   #1
1977 31' Excella 500
Bonnyville , Alberta
Eliminate Roof Vents??
Hi Guys,
I think IMO 1 air conditioner, 3 roof vents, 2 exhaust fans, and 1 fridge vent is quite excessive. I want to eliminate the 3 roof vent/fans/light fixtures as they are common source of leaks etc.. I will just patch the 13" by 13" holes on top and patch and install light fixtures on the inside or maybe a skylight. I live up in alberta where heat and humidity aren't too bad and the AC unit is good enough.
Your thoughts?
Zenstream1 is offline   Reply With Quote
Old 08-02-2015, 12:27 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I would get rid of the air conditioner first because we use the roof vents constantly, never the air conditioner. We put MaxAir vents over them so they can be open in the rain or going down the road. They're open near 100% of the time including when the Airstream is not in use.
Doug and Cheryl
Old 08-02-2015, 12:33 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Definetly would be a deal breaker if I was looking to buy. But it is your trailer to do with as you please.
MICHAEL
Old 08-02-2015, 02:31 PM   #4
cameront120's Avatar
1972 25' Tradewind
I'm with Doug. I'd be upgrading the vents per his recommendation. It might be enough to eliminate the use of your air conditioner altogether.
North Vancouver, BC
Old 08-02-2015, 04:26 PM   #5
Does Maxair work in the factory vent size?
Old 08-02-2015, 04:36 PM   #6
andreasduess's Avatar
1984 34' International
Toronto , Ontario
I live in Ontario, we use the vents all the time, even more so than the AC. I find them to be an absolute necessity.
andreasduess is offline   Reply With Quote
Old 08-02-2015, 04:40 PM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We have Maxair vents and love them. We had to square up the openings a little, if I recall correctly, but otherwise they install easily. It's easy to cool the trailer with the vents open and exhausting out, and windows open in the trailer to draw air in. Very little air conditioning used for us. Our vents are open in storage at home also for ventilation in the summer in the trailer. We've never had rain come in, ever with these vents.
Oh, and we did eliminate our center vent. Never used that one.
Kay
Old 08-02-2015, 06:15 PM   #8
I would be in for a little more than squaring up. My Rough Opening is only 12" x 12" and there is an aluminum frame in between. Has anyone else cut into these to expand the rough opening?
Old 08-02-2015, 06:37 PM   #9
Or is that aluminum frame part of the original fan ??
Old 08-02-2015, 07:54 PM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It is done all the time, remove the rivets from the stock unit, remove the frame, cut bigger hole, install your choice of fan
Old 08-02-2015, 08:34 PM   #11
Sounds good man. Thx ^^
Eliminate WD issue with water! gamana Hitches, Couplers & Balls 68 10-28-2015 06:03 PM
How do I eliminate the musty mouse smell?? mrrealtor General Interior Topics 30 04-16-2015 04:00 PM
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
First dog in AS - how do you eliminate that dog smell? Whirlaway The Pet Forum 42 03-22-2010 05:54 PM
Eliminate black water tank? macman Waste Systems, Tanks & Totes 17 07-02-2006 09:47 AM
