Old 12-03-2009, 08:35 AM   #1
Hedonistic Bohemian
Bohemian's Avatar
2007 27' Safari FB SE
Atlanta , Georgia
Drip inside, how to find the leak outside?
My Airstream leaks. Not bad. I have a plastic cup attached to the ceiling via suction cup which catches most of it.
Trouble is, I'm just observing where it leaks through the inner skin seam. It could have leaked through in a bunch of places and drained over to this point - a vent, rivets, etc.
Observed drip is between rivets on this seam about 15" to the curb side of the center.
How can I tell where the leak is on the roof? Is there a procedure for this?
Bohemian is offline   Reply With Quote
Old 12-03-2009, 10:36 AM   #2
Kevin245's Avatar
Hello Bohemian,
I would start by getting up on the roof. Often times the leak source can be identified by looking at the sealing surfaces around roof penetrations. A small hole, seam, or opening in a seal or sealant can allow the water in. So it pays to visually examine vents, AC, antenna, and any other openings on a routine basis. We make it a point to do a roof examination each Spring and Fall.
The other thing to consider is that water will travel the path of least resistance, so the leak may or may not origniate at the point you notice it inside.
A sure way to trace leak sources is with a pressure test. Here is a recent thread where a member did his own testing using a leaf blower and some ingenuity.
http://www.airforums.com/forums/f44/...highlight=Leak
You can also contact soldiermedic (Steve) as he provides this service as well, or there may be a vendor in your area who can provide this service.
Good luck,
Kevin
Eleanor Roosevelt
Old 12-03-2009, 11:06 AM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Wrap an old blanket around a ladder.....go topside for
a close examination...if your trailer is leaning now, consider
the angle as you search for the offender
kennethowens is offline   Reply With Quote
Old 12-03-2009, 12:07 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
up on the roof..
This would be the first place I would look....
Black tank vent..
Name:	SOLAR PANELS; ROOF LEAK 011.jpg
ID:	91979   Click image for larger version
Name:	SOLAR PANELS; ROOF LEAK 023.jpg
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-03-2009, 12:29 PM   #5
Kevin245's Avatar
Good point.
Which also brings up another point if you're not experienced working on your roof. To avoid damage when accessing and working on your AS roof, avoid walking on the end caps and stay on the rib lines when moving around. I use a couple of 18" square pieces of masonite for kneeling pads when working on the roof. They're lightweight, easy to move around, and help spread my weight out a bit.
Kevin
Eleanor Roosevelt
Old 12-03-2009, 02:15 PM   #6
Astroboy's Avatar
2007 28' International CCD
West Hollywood , California
I heard that grey/black tank vents are susceptible for leaks because of how the Airstream shell flexes on the road while the vent pipes shake and move up and down.
After about 4000 miles of Fwy travel in a year...
I had leaks from both at grey vent and black vent, and from one of the skylight.
- There were occasional drips along the ceiling panel seams at right next to, and at both sides of, my grey vent, in my case.
- The curbs (or the aluminum frames) of the skylights are usually caulked very thickly with sealant at its outer seams (the junction between the curbs and the outer roof panels). The leak is more likely at the inner seams (where the domes and the curbs meet) or at one of the many screw holes. If you remove the skylight shade and the trims from inside your trailer, you can check if its leaking. You can stick your fingers (be careful, don't cut your fingers!) to the surrounding fiberglass mat and see if they are soaked with moisture.
Just sharing my experiences with my 1-year old trailer.
Astroboy is offline   Reply With Quote
Propane Leak Inside Trailer neil.ervin LP Gas, Piping, Tanks & Regulators 14 09-22-2009 08:22 AM
Arrggggg! Drip, Drip, DripóWarning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
can't find leak tobynamy Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-19-2006 08:07 PM
How to find a water leak eddo Fresh Water Systems 9 08-26-2005 02:04 PM
Can Not Find Leak Help! Rennegarbe1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-12-2003 04:08 PM
