Old 03-29-2011, 02:31 AM   #1
1969 27' Overlander
Esbjerg , Jylland
Send a message via ICQ to Luc_DK Send a message via Skype™ to Luc_DK
Drainage system roof vent is missing..
Hi
i just started a resto job on an old AS 1969 Overlander.
I need a new cap/vent cover for the Drainage system (bathroom roof)
where can i buy a new one ?
i prefer original. but improvement will be accepted, if it looks okey :-)
rightnow the roof hole in covered with something that looks like a grey sprayed cola can !!!!!!
see attached picture.
Regards
Peter
Luc_DK is offline   Reply With Quote
Old 03-29-2011, 04:30 AM   #2
tinhutjoh's Avatar
1974 29' Ambassador
London , Ontario
Have a look at Fantastic Fans. I had the cover on my one fan blow off in the wind and the solution my Trailer Guy came up with, was to replace it with a Fantastic Fan. Best thing I've done as the fans are great. I believe you can get a silvered cover with it when it's ordered. BTW it meant I lost a roof light and interior vent cover, but it was a good trade off to make.
tinhutjoh is offline   Reply With Quote
Old 03-29-2011, 04:53 AM   #3
1969 27' Overlander
Esbjerg , Jylland
Hi
i think you misunderstod my question..
i dont need a new FAN..
please look at the picture again, i only need the little vent. cap/cover (it's missing so i dont know how it looks) from the drainage system.. you can see the buttom of the cola can :-)
above the orange light...
/Peter
Old 03-29-2011, 05:29 AM   #4
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I believe Andy said that they had them at Inland RV.. It was that or duct tape.. don't remember exactly.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-29-2011, 05:30 AM   #5
x
XXXX , XXXX
Peter here is what you need.
Inland RV Center Inc.
wasagachris is offline   Reply With Quote
Old 03-29-2011, 07:19 AM   #6
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
This one is only $6 from VTS. Metal Roof Pipe Cover
Get the butyl tape when you make your order. I also used the larger sized pipe insulation around the actual vent pipe.
robwok is offline   Reply With Quote
Old 03-29-2011, 07:23 AM   #7
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Pic of mine
here's a pic of mine after I polished the area around it, and painted the cover.
Old 03-29-2011, 07:25 AM   #8
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
A trick someone else showed me. Buy a stainless steel sink strainer from the kitchen dept in any store. I actually then cut the rim around it and pushed it to fill the inside of the vent. That keeps wasps from making nests. You can put just a couple of the wires on the outside of the rim, and the rest inside. That friction fit will keep this wire "cage" just on the inside so it maximized the space. If you just cover the pipe, the wasps can still make nests around the vent, so it may not clog the tube, but not sure if it will work as well.
Old 03-29-2011, 07:43 AM   #9
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you want a replacement that looks like the one you have go to Vintage Trailer Supply. Inland sells the newer style stack covers. Since I had two original vents in good shape on my 68, I went with the ones from VTS so all three would look the same. Both styles work and don't leak if installed correctly, it just a matter of which look you like.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 03-29-2011, 07:43 AM   #10
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
This is what came original on the 69 AS Airstream Plumbing Stack Cover I relaced mine with http://www.inlandrv.com/catalog/imag...entpipecvr.jpg
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 03-29-2011, 07:54 AM   #11
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
arodriguez60 has it right. Original and the newer replacement. Note...there is no "cap" for it. Be sure the base seal is good.
Old 03-29-2011, 08:38 AM   #12
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
the one from VTS is metal. I found this thread for an aluminum one. I just called and ordered one last week.
http://www.airforums.com/forums/f455...light=vent+cap
Tim
GeocamperAS is offline   Reply With Quote
Old 03-30-2011, 01:25 AM   #13
1969 27' Overlander
Esbjerg , Jylland
Hi all
thanks for info...
I have looked at the replacement from inland, but i dont like it's open.
i would like a cap to hold rain out..
maybe i will try to get the Aluminiun one from Mobile Home Depot.
but can it be ordered online ?
i cant find it on their website...
/Peter
Old 03-30-2011, 05:28 AM   #14
1974 Argosy 28
Images: 37
Tim
#8 on that same thread had the phone number.
239-543-3300
I called on 3/21 to order one.
I am expecting it any day now.
$ 9.99 part
$13.50 shipping
$ 1.41 tax
$24.90 total
I did question the tax because I am not in the FL and they do not have a store in WI. I got the impression they are a one store operation and don't do many phone orders. I was not going to argue for a buck.
50's Hehr roof vent lifter arm rivet tool vintageair Roof Vents, Skylights & Fans 12 06-29-2011 01:37 PM
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Shorten crank on roof vent? Breadbug Roof Vents, Skylights & Fans 4 01-31-2011 09:43 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
