Old 02-12-2006, 09:59 PM   #1
dented roof panel, with popped seam, Hard Fix??
We went and and looked at a 65 globtrotter today that has what looks to be a dent in the roof that maybe was caused by something falling on the roof. It seems to have popped a seam. Is this an easy fix? Can it just be pushed out, re riveted and sealed, or would the panel need to be replaced/patched?
dkutz is offline   Reply With Quote
Old 02-13-2006, 07:49 AM   #2
well I don't own it, and we went and looked at it in the dark (couldn't wait) last night sooooo.
Old 02-13-2006, 08:51 AM   #3
1975 29' Ambassador
Reno , Nevada
Popped rivets often indicate significant problems. Dents can often be pushed out but once aluminum stretches it stays stretched. Creases won't go away either.
What I'd worry about is the ribs getting bent. Does the inside show evidence of the impact?
To see some dents, check out Dave's trailer
http://sierranevadaairstreams.org/me...m/gallery.html
We are trying to figure out how to get a new rib shipped in as one was broken. The others can be 'adjusted' to somewhere near where they should be. The front roadside dent cleaned up pretty well except for the gash near the bottom. The front top dents also pushed out fairly well.
I guess a lot just depends upon how perfect you want the result to be.
Old 02-13-2006, 11:27 AM   #4
thanks for your help. We just got back after looking at it in the light, and its a mess. Looks like maybe a tree fell on top,of course right on a rib in the middle of the trailer. The roof is a wavy mess. So the search continues.
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
