Old 05-13-2014, 12:09 PM   #1
2008 23' Safari FB SE
Santa Ynez , California
Clear coat pealing
My wife and I purchased a 1997, 27' Safari from the original owner about 2 years ago. It was in very good shape and we have had some minor work / maintenance done to it. However, we do not have a covered space, or garage to store it in. The clear coat was pealing when we purchased it and I want to protect it until we can have it redone.
Can anyone suggest a sturdy car cover, like the ones you see in people's driveways, or some way to cover the Airstream until we can have the clear coat removed and replaced?
Thank you,
Brian
Brian Bailey is offline   Reply With Quote
Old 05-13-2014, 12:26 PM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
When you say car cover are you referring to the fitted covers that wrap and sit directly on the vehicle? If you search on the forums you will find covers are not recommended for Airstreams and can do more harm than good to your clear coat.
Landrum is offline   Reply With Quote
Old 05-13-2014, 01:31 PM   #3
Thank you,
Brian
NO COVERS, EVER
If your planning on having the trailer refinished, then in the meantime apply some clearcoat that is available from Airstream dealers in spray cans.
It won't look too bad, but it certainly will protect the metal.
Old 05-13-2014, 06:46 PM   #4
Car canopy, not cover
I meant a canopy large enough to park the Airstream under it. Any recommendations?
Can you apply the spray clear coat over the old clear coat as a temporary protectant?
Old 05-13-2014, 06:56 PM   #5
r carl's Avatar
Lin , Ne
Yes
r carl is online now   Reply With Quote
Old 05-13-2014, 07:24 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
OP, I have portable garage I bought thru Amazon. Heads up, the covers only last about a year and then you have to buy and install another.
MICHAEL
Old 05-13-2014, 09:53 PM   #7
Absolutely yes.
Galley Sink Paint Pealing Off Cracker Sinks, Showers & Toilets 1 04-21-2008 05:47 PM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 09:26 PM
Full Timing in Trlr w\pealing Clearcoat route66 Full-Timing 4 11-25-2005 03:50 AM
vinyl pealing off cabinet doors ?????? vtjoesmith Cabinets, Counter Tops & Furnishings 0 11-20-2003 08:09 PM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 08:23 AM
