Old 03-17-2019, 05:48 PM   #1
2015 30' Flying Cloud
Vancouver Island , British Columbia
Can anyone tell me what is that strip protecting or what’s its role
I’m trying to figure out what that strip is protecting. Is it dicor sealant ?Click image for larger version
rintintin is offline   Reply With Quote
Old 03-17-2019, 05:52 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
It is Dicor and it is covering a roof seem. The roof of your Airstream is wider than a single sheet on Aluminum. So there is a second smaller piece to complete the roof.
Dept of “OverKill”
Old 03-17-2019, 05:54 PM   #3
Thanks. Would you remove the dicor and replace with Adseal?
Old 03-17-2019, 06:03 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Dicor is fine for that joint. You could also use Alpha-one self leveling sealant.
Dept of “OverKill”
Old 03-17-2019, 06:56 PM   #5
Thanks for the help I really appreciate it
Old 03-17-2019, 07:33 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Originally Posted by rintintin View Post
I’m trying to figure out what that strip is protecting. Is it dicor sealant ?Attachment 335923
IMO, that is a big gob of caulk that should not be there. (my trailers are 20+ years old and there is none exposed there) When the trailer came from the factory there was no caulking on the surface of that long overlapped metal seam. If it leaks there it would not be normal. If there is actually a leak there it would probably be a loose rivet. A very thin penetrating caulk on the rivets, not the joint, would be better. I've used Acryl R on seams and rivets, but there are other sealants that are thinner and flow more easily that might be better for loose rivets.
http://odmrv.com/catalog/index.php?m...oducts_id=1164
If it were me, I would remove all of the caulk along that long line, and not replace it, to see if it actually leaks. (The fans and skylight are more likely leak sources)
If you do decide to replace it, there are better choices than Dicor. My experience has been; Dicor will crack in a year or so due to exposer to UV. (a search will confirm others who have had this same experience) Adseal is a silicone caulk. Since silicone caulk rejects adhesion to itself, any future caulking might be an issue. A urethane caulk with UV resistance would be a better choice, IMO.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 03-17-2019, 07:41 PM   #7
Ok thanks
Old 03-17-2019, 07:50 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
It's there because of laziness plain & simple. 👎
My trailer was far from perfect when delivered, and it did have roof vent leaks, but it looked nothing like that.
This was taken last year after cleaning & re-seal.
ID:	335945   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-17-2019, 09:39 PM   #9
Originally Posted by ROBERT CROSS View Post
X2
Great photos
Old 03-25-2019, 08:20 PM   #10
Don't know what year that seam is on... but its ugly!
Gonna be a bear to scrape off too.
Me, I'd paint the roof white, with the roof paint of your choice...
Double whammy...
1/ Reflects heat and lowers interior temps by 10 t0 20%...
2/ Seals all rivets, joints, etc.
You could spend a week scraping that off if you feel like it, or just paint over it!
Old 03-26-2019, 10:56 PM   #11
The roof is actually already painted white. Ill remove the caulk as the weather gets better. Its a 2015 trailer
Old 03-26-2019, 11:11 PM   #12
Great photos
That was just a cleaning...Scotch Pads, Brakleen and Blech-Wite Tire Cleaner.
Re-seal with CTCCC and 3m 5200 where needed for wide gaps.👍
W. H. Auden
Amanamus
"Tahawus"
Battery charging: role of the converter when there are solar panels? Runaground 2016 - Current International 32 10-30-2017 05:47 AM
help!! can anyone tell me how to convince my hubby! staceydr200 2005 and newer - Bambi all models 23 10-05-2008 10:03 PM
Can anyone tell me.... BIGED52 Off Topic Forum 14 02-17-2007 12:50 PM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
Can ANYONE tell me what this is?!?! duke208 Our Community 30 11-11-2004 05:17 PM
