Old 08-31-2015, 08:30 AM   #1
83 Excella - 27
PeterD's Avatar
1983 27' Excella
Temecula , California
Best way to patch the roof
I am going to remove the ancient TV antennae on my 1983 Excella.
What is the best method to cover the hole ?
PeterD is offline   Reply With Quote
Old 08-31-2015, 08:50 AM   #2
Kevin245's Avatar
We were on the road when the antenna penetration on our Avion started to leak. I pulled the antenna off in the Ace Hardware parking lot and applied a patch over the holes using vulkem. The patch is an aluminum sign, but it is still in place six years later.
Eleanor Roosevelt
Old 08-31-2015, 09:11 AM   #3
1972 27' Overlander
puyallup , 98373
me and my boyfriend are working on the same thing. we noticed a leak 2 days ago and are going to remove the antenna while we are up there. ( the antenna cant be useful in any way can it ?) my boyfriend says nope its " gotta go"
we are going to solder ours, ( is our 1st plan)
or use aluminum patch and rivet and use a seal chalking.
firstremodel is offline   Reply With Quote
Old 08-31-2015, 10:04 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Get some aluminum and cut to some fun shape. (Hearts are popular, but so are other shapes!) Apply with Olympic rivets and Vulkem!
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 08-31-2015, 10:13 AM   #5
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
I would patch with butyl tape as he sealant use SS screws (short) to fasten patch. Slightly counter the holes if the roof. One of the advantages of the butyl is if you ever want to remove the patch you have that ability forever.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 08-31-2015, 11:19 AM   #6
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Air Flo
Shape the patch as a teardrop, seal as above and pop rivet in place...vulklem.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 08-31-2015, 02:49 PM   #7
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Solder won't work on aluminum. Get a piece of about 12 to 14 guage of aluminum, and some good caulking. Cut your aluminum so you've got about a 3" overlap around the hole. Coat both, the roof and the patch with a thin coat of caulk.
Using 1/8" waterproof "Pop" rivets, about 2" apart, and you should be good for eternity.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 09-01-2015, 10:31 AM   #8
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Good Buddy
Replaced ours with a CB antenna.
That is stainless steel popped down, the mess outside is left over valkum...tough stuff.
Click To See Me Wet
1972 Argosy 24'...
Roof patch solution? Glt12 Ribs, Skins & Rivets 4 06-26-2015 12:22 PM
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
What to patch the roof holes with? wvabeer Land Yacht/Legacy Motorhomes 24 04-22-2013 03:53 PM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
Roof re-enforcement/ patch GnJ Roof Vents, Skylights & Fans 2 05-04-2010 08:00 AM
