Old 08-26-2016, 01:35 PM   #1
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
Best way to get on top
What is the best way to get on the roof to service anything on the roof? Check for wear tear "stuff". I use my ladder, but I can only get so close, and can not see what I need to see.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-26-2016, 01:53 PM   #2
I think I saw a youtube video through Colonial Airstream with Patrick showing how to get onto the roof.
BetterNowlinLater is offline   Reply With Quote
Old 08-26-2016, 02:14 PM   #3
I just went back and looked. It is called How to climb onto the roof of an Airstream. From December 2014. I don't know how to post it on here.
Old 08-26-2016, 02:17 PM   #4
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
For your model, I would wrap the top ends of the ladder with towels or rags. Then lean the ladder against one of the "brows" over a window. The brows, or drip guards are stronger and can distribute the weight. Make sure the bottom of your ladder that touches the ground is secure and climb on up. Have someone spot you from below. Wear shoes with rubber soles or something similar that has a good safe grip. Look for the rivet lines on the roof and stay on those. Don't step in between them. Take your time and you will be fine.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-26-2016, 02:28 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have a 22 ft Little Giant that is very stable when extended. I lean it against the trailer on big foam pad. I then put the base against the house or some other heavy object so as I gets past the resting point it there is no way it will move. If you don't make sure the base is firm when you get to the top and lean over to step off the weight shift makes the bottom light and it will slide away from the trailer (how do I know this). Be careful and have someone around anytime you are on top in case you need help or the ladder shifts.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-26-2016, 02:36 PM   #6
1976 31' Sovereign
Oswego , Illinois
An extension ladder or 1 long enough to lean against awning cover when retracted. Aluminum ladder won't hurt cover as it's stainless or put or something over ladder then lean against. Make sure bottom is secure so won't slip. I put bottom against house and onto awning. This is for awnings that have metal cover, could do same for awnings w/out cover by padding ladder. I have never scratched cover, some times throw blanket over back side of ladder.
Old 08-26-2016, 04:13 PM   #7
2014 25' FB International
Metuchen , New Jersey
Great suggestions! I've always wondered how people did this.
GenXair is offline   Reply With Quote
Old 08-26-2016, 04:13 PM   #8
Stay CazuaL
cazual6's Avatar
Reseda , California
Wish me luck. Thank you
WBCCI 9164
Old 08-27-2016, 12:26 PM   #9
Native143's Avatar
2014 16' Sport
Dunedin , Florida
I had to replace my antenna yesterday. So I put a "noodle" over the top edge of the ladder to cushion it, made sure the bottom was stable, and then put a patio lounge cushion on the top of the roof and laid across that to reach the antenna. That extends my reach to the center of the roof so now I can clean, inspect, do whatever without having to walk on it.
"I'd rather rust out than wear out"
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 08-27-2016, 12:31 PM   #10
Long Island , New York
Here are the search results for "ladder roof access" using the lower (Google) search function in the Search link above:
https://cse.google.com/cse?cx=011403...ess&gsc.page=1
Plenty of good advice in the earlier threads, in addition to that given here already.
Have a good weekend.
Peter
Old 08-27-2016, 12:45 PM   #11
Full Timer
2006 28' Safari S/O
Newport , North Carolina
To avoid the chance of denting the roof, I put down a 24" x 36" piece of plywood as a work space. I've glued a rubber mat on the underside to prevent slippage. This creates a secure platform, and eliminates a couple of big worries.
mpawilliams is offline   Reply With Quote
Old 08-27-2016, 01:26 PM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You can avoid the chance of falling off the roof with disastrous results by leaning a ladder against the side with padding to protect the trailer or awning surface, if the ladder is tall enough to stand on it and reach the center of the trailer easily.
This will allow you to do inspections and most service without crawling on top. I installed my fan covers easily standing on a ladder (I actually put one on each side for this) and didn't have to crawl off the roof to get another tool or recover a dropped screw.
I think it's a safer way to service the roof components.
Doug and Cheryl
Old 08-27-2016, 01:46 PM   #13
2015 30' International
FREDERICK , Maryland
here is the Colonial video
Doc Foster is offline   Reply With Quote
Old 08-27-2016, 02:46 PM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
When I'm at home I use different tools for different jobs, a combinations of step ladders, extension ladders, and scaffolds with walk boards. It depends on what I need for the specific job I'm trying to accomplish.
I had an experience while on the road that I needed to get on the roof when a fan lid blew off. To make it worse, it was raining.
So, I'm in the market for some type of collapsible, telescoping, or folding ladder that will fit inside my Airstream, without taking up to much room. I'm trying to sort out what's best.
I'll need a class 1A ladder for my .... stout physique.
Any suggestions?
Alan
Best way to get 120V 30 AMP from a 5 KW generator Hummer Electrical - Systems, Generators, Batteries & Solar 8 10-31-2014 09:47 PM
Best way to get over mountains? Smoky On The Road... 16 04-30-2013 05:42 PM
Best way to get an older day night shade replaced? AtomicNo13 Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2012 04:18 PM
What's the best way to get to U channel when replacing a section? kramynot2000 Repairing/Replacing Floor &/or Frame 7 05-21-2007 01:08 PM
