Old 08-27-2016, 03:41 PM   #15
UT , Utah
I drilled additional lock pin holes in my Little Giant ladder so I could remove one of the extensions, bend the shortened section to fit the AS roof angle, attach a well padded piece of plywood to the end of the shortened section so I can bend over the ladder and work on the roof safely and comfortably even with my overweight 72 year old body.
Vic Orvis is offline   Reply With Quote
Old 08-27-2016, 04:14 PM   #16
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
A padded top end of my ladder, with a heavy folded blanket over the awning tube, and a spotter at the bottom of the ladder, leads to one more issue. Your belt buckle on your pants can scratch the heck out of anything you are sliding over. Wearing jogging pants, or a swim suit or something without a buckle or rough button on the front, will help prevent scratching things you don't want to deface. Its not only scratching the aluminum, its scratching the clear coat as well. Good luck.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 08-27-2016, 04:20 PM   #17
2014 25' Flying Cloud
Temple , Texas
I use the inexpensive foam knee pads they sell at Harbor Freight - they have velcro straps to wrap around the top of the ladder. Easy to take off and save for next time.
2014 Flying Cloud 25FB
2016 Ram 1500
Blue Ox WDH
RamRider is online now   Reply With Quote
Old 08-27-2016, 04:24 PM   #18
FCStreamer's Avatar
2014 30' Flying Cloud
Originally Posted by A W Warn View Post
When I'm at home I use different tools for different jobs, a combinations of step ladders, extension ladders, and scaffolds with walk boards. It depends on what I need for the specific job I'm trying to accomplish.
I had an experience while on the road that I needed to get on the roof when a fan lid blew off. To make it worse, it was raining.
So, I'm in the market for some type of collapsible, telescoping, or folding ladder that will fit inside my Airstream, without taking up to much room. I'm trying to sort out what's best.
I'll need a class 1A ladder for my .... stout physique.
Any suggestions?
This is the one I got.
http://www.ourflyingcloud.com/2016/0...ot-ladder.html
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2013 Cadillac Escalade Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 08-27-2016, 05:06 PM   #19
1976 31' Sovereign
Oswego , Illinois
Smile
Wearing swim suit on sunny day will result in some nasty burns as Aluminum gets very hot. Sweat pants works very well.
Old 08-27-2016, 05:33 PM   #20
Boxite's Avatar
2008 22' Sport
There are a number of telescoping ladders available. The "Xtend" brand is popular. Walmart and Home Depot both carry them, and Amazon is always a good place to start looking. The advantage of a telescoping ladder is that it is sufficiently compact that it can be carried on trips with very little room taken.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-27-2016, 06:42 PM   #21
1967 24' Tradewind
Hughesville , Pennsylvania
Check out the Werner 16. Foot multi position ladder. It's really nice for working on the roof of your airstream and use it as scaffold for waxing up high. It can be positioned into multiple setups from extension, step, scaffold. It lets you stay on the ladder in the middle of your roof.
snookduff is offline   Reply With Quote
Old 08-28-2016, 05:58 AM   #22
Full Timer
2006 28' Safari S/O
Newport , North Carolina
It's a bit pricey, but in IMHO the best class 1A ladder for carrying on board is the Telesteps 1600EP. It has a 300 lb capacity, is rock solid and telescopes into a package that fits between the back of the sofa and the front wall of my Safari. Whenever I can, I also anchor a length of 5/8" nylon rope to something on the far side of the trailer - this acts as a safety line, and helps a lot in the process of getting me from ladder to roof and vice versa.
mpawilliams is offline   Reply With Quote
Old 08-28-2016, 06:07 AM   #23
Long Island , New York
Thanks for the details, and welcome to the forum! For everyone's info, FCStreamer has a link for the Telesteps in Post #18. OSHA compliant as well.
Old 08-28-2016, 06:11 AM   #24
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Yes, but that's a different model. Here is the 1600EP on Amazon:
https://www.amazon.com/Telesteps-160...telesteps+1600
SeaLevel is offline   Reply With Quote
Old 08-28-2016, 06:40 AM   #25
Thanks for the correction. Yours has a longer reach which might be useful.
Old 08-28-2016, 07:55 AM   #26
+1 on this product. We carry ours everywhere we go. Pricey but worth it.
Best way to get 120V 30 AMP from a 5 KW generator Hummer Electrical - Systems, Generators, Batteries & Solar 8 10-31-2014 08:47 PM
Best way to get over mountains? Smoky On The Road... 16 04-30-2013 04:42 PM
Best way to get an older day night shade replaced? AtomicNo13 Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2012 03:18 PM
What's the best way to get to U channel when replacing a section? kramynot2000 Repairing/Replacing Floor &/or Frame 7 05-21-2007 12:08 PM
