Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 06-12-2018, 04:06 PM   #1
Montrose , Colorado
Attaching a new Roof Vent
Howdy all!
I am finally removing the old A/C unit from my Argosy, and putting a pretty standard roof vent in its place. The question I have is should I use the recommended #8 3/4" hex-head stainless screws to put it down (prior to sealing), or should I use 1/8" rivets instead? Thanks for any suggestions!
1978 Argosy Twin 24'
Montrose, CO
Bartowski is offline   Reply With Quote
Old 06-12-2018, 04:12 PM   #2
2007 22' International CCD
I'd go with the SS screws...if you ever need to remove the vent, that would be lots easier than drilling out bunches of rivets...
Old 06-12-2018, 04:15 PM   #3
1981 31' Excella II
New Market , Alabama
Ya might want to use pan head stainless screws since they don't stick up as much and might be easier to seal. They might also be harder to remove with caulk in the screw head. If you are sealing with something like eternabond tape the pan heads might work better. I would also get a vent with a metal frame if you don't want the flange to crack and cause leaks.
Perry
Old 06-12-2018, 04:52 PM   #4
Montrose , Colorado
Perry
Great advice Perry - thanks! Going to tape for sure, and use Dicor Lap Sealant to seal it all up. Also, I did get a vent with a metal frame for exactly the reason you stated.
Montrose, CO
Old 06-13-2018, 08:36 AM   #5
Montrose , Colorado
How much Dicor to use....
Forgot to ask - how much Dicor does it typically take to fully seal one of these vents? 2 tubes?
Montrose, CO
Old 06-13-2018, 09:11 AM   #6
2006 30' Classic
1966 20' Globetrotter
Dover , Delaware
Less than one tube, use just enough to seal.
helwigc is offline   Reply With Quote
Old 06-13-2018, 11:30 AM   #7
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
What is the brand of vent that you are installing?
Thanks!
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Old 06-18-2018, 05:52 PM   #8
Montrose , Colorado
Thanks!
Sorry for my slow response! Hengs Universal vent - going inexpensive for now, as I know we will likely replace it in a year or two!Click image for larger version
Montrose, CO
Old 06-18-2018, 08:38 PM   #9
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
5 years slows [emoji12]
Matt
rugjenkins is offline   Reply With Quote
Old 06-18-2018, 09:15 PM   #10
2010 25' FB Flying Cloud
Davenport , Iowa
Place a 2x2 between the inner and outer skin to add a more stable to fasten to. Otherwise the AC will only be anchored to the outer skin and will vibrate. The same is true with the vents.
Airtandem is offline   Reply With Quote
Old 06-19-2018, 04:30 PM   #11
Montrose , Colorado
Great advice - thanks!!
Montrose, CO
Change a metal roof vent by a transparent roof vent ? Gaël Roof Vents, Skylights & Fans 11 12-27-2014 05:55 PM
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
Wires/Power for stove vent & roof vent. Jeepers! 1956 - 1965 Caravel 3 10-03-2014 09:21 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
