Old 06-13-2015, 02:48 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Astrodome replacement procedure
Howdy!!!
Our 99 Excella has a warped and aged/ original astro/Astra dome on the bow roof vent.
It appears to be mounted to two aluminum "L" bar with closed end rivets. Once I remove the rivets, should I reinstall with screws, washers and Nylock nuts or re-rivet?
Anyone done this and cares to share their experience?
Thanks!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-22-2015, 03:20 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ok... So I figured it out... Cut off the rivets. Re-rivet using 1/8" dis, 3/8"grip range rivets. Dab of sealant (arsenal) on rivet exterior.
Channing
WBCCI# 30676
1965 Astrodome replacement alternatives Kreimer Roof Vents, Skylights & Fans 2 08-21-2015 11:39 PM
Serpentine belt replacement tips and procedure 454 LY 30 DaveFL Mechanics Corner - Engines, Transmission & More... 9 06-02-2009 09:00 PM
Astrodome Replacement Cochese Roof Vents, Skylights & Fans 2 09-10-2007 02:05 PM
PA Winterizing Procedure pbnjsellers General Motorhome Topics 2 11-15-2004 04:26 PM
