Old 09-23-2017, 07:23 AM   #1
1995 30' Excella
Harper Woods , Michigan
are pop-rivets considered self-sealing?
Hello, while investigating a leak in the back end of the 94 28' Excella, I found a hole with no rivet in it at the very end of the awning rail. Looking down the length of the trailer, I see a long line of pop-rivets along the awning rail that have holes in the center. Shouldn't these holes be filled, or do the rivets seal upon installation? Also, I see a few with the stem poking up about 1/4". The PO reported that several years back, the entire left side had been replaced at a dealer after rubbing a tree branch ($11k cost), and I'm wondering if was done correctly, and just how bad things might be along the floor-to-wall junction.
So, should I use Capt Tolley's crack sealer in the rivet hole(s), or sikaflex 221? And by the way, there are lichens growing on the roof. What would be the best way to remove them?
Bob Blarney is offline   Reply With Quote
Old 09-23-2017, 07:33 AM   #2
2000 30' Excella
Toledo , Ohio
Pop rivets are not self sealing cover the holes with caulking .
woodfox45 is offline   Reply With Quote
Old 09-23-2017, 07:43 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
There are closed end pop rivets available that are sealed. You just need a dab of vulkum in the hole before inserting. We used them on our belt trim when we reattached it. It's very hard to tell the difference once they're installed.
Kay
Old 09-23-2017, 10:36 AM   #4
1995 30' Excella
Kay
Thanks. And I'll dab them with some caulk.
Old 09-23-2017, 11:22 AM   #5
2014 22' FB Sport
Mill Valley , California
The rivets available from Airstream have a sealing washer and are designed to be smooth on top after installation. For the right finish look, you would need a "rivet cutter" unless you are really good with a "Dremel"
Using hardware store pop rivets will not seal reliably and will show a hole in the middle of the rivet when done.
Andrew
awiegel is offline   Reply With Quote
Old 09-24-2017, 06:07 AM   #6
1995 30' Excella
Andrew
It's not my intention to redo the dealer's work. I just need to know if the the work done by the dealer is a permanent leakproof repair, or do I need to 'refresh' the sealing. I'm thinking of applying Eternabond.
Old 09-24-2017, 04:08 PM   #7
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
Repairs should not have been made with POP Rivets... they are not structural strength... they should have used the olympic or cherry max brand blind rivets and shaved them after pulling them ... you can't get 'em at the big box stores... you have to go to the aircraft supply stores and get them their... along with the tooling you need to pull and shave 'em ....
I would be asking questions as to structural intergerty from the PO... and who did the work.. ask them why they didn't use the right ones... Pop rivets will eventually work lose... again... under loading and vibration... they are at best a weak rivet...
We work on Aircraft.. and our airstream... has lots of good parts holding it togeather ... I am sure the factory will nod about the soft pop rivets being used .. if that is what your saying... they are... with holes in the middle... and missing stems... Sealing them will keep the water out.. but... when the two pieces of sheet metal move... they will raise their ugly heads again and start leaking...
GM Airstream is offline   Reply With Quote
Old 09-25-2017, 12:26 PM   #8
1995 30' Excella
Well, that sounds ominous. Maybe i'll get up there and take pic. I'll ask the PO how long ago the work was done. It was paid by an insurance company, so I wonder if they would be interested too.
So the next question is, "What to do?" For now, maybe I should consider a continuous length of Eternabond or 3M Extreme tape to cover it all.
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
HepvO Self Sealing Gray Valve Pams72 Waste Systems, Tanks & Totes 3 02-15-2014 02:40 PM
Has anyone considered downsizing in these tough times? Silver Threads Full-Timing 83 02-26-2009 07:58 PM
Tradewind Purchase Being Considered s_zamora Member Introductions 11 10-06-2008 09:33 PM
