are pop-rivets considered self-sealing?
Hello, while investigating a leak in the back end of the 94 28' Excella, I found a hole with no rivet in it at the very end of the awning rail. Looking down the length of the trailer, I see a long line of pop-rivets along the awning rail that have holes in the center. Shouldn't these holes be filled, or do the rivets seal upon installation? Also, I see a few with the stem poking up about 1/4". The PO reported that several years back, the entire left side had been replaced at a dealer after rubbing a tree branch ($11k cost), and I'm wondering if was done correctly, and just how bad things might be along the floor-to-wall junction.
So, should I use Capt Tolley's crack sealer in the rivet hole(s), or sikaflex 221? And by the way, there are lichens growing on the roof. What would be the best way to remove them?
