Old 11-17-2010, 11:56 AM   #1
1969 27' Overlander
Gold Hill , Or
Antenna removed from '69 Overlander; need it?
I have removed the antenna from my trailer and am wondering if anyone might need it for a restoration. I will not replace it and don't want to junk it if someone could use it.
Jay
jayg is offline   Reply With Quote
Old 11-17-2010, 12:17 PM   #2
1968 26' Overlander
West Richland , Washington
Jay, if this is a roof mounted unit, I would appreciate having it as mine is missing. Is there also a crank to go with it?
JIMandPJ is offline   Reply With Quote
Old 11-17-2010, 12:41 PM   #3
pinktrailer's Avatar
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Jay
Oh my gosh! I took the one off my '67 (front, road side) and brought it to the dump. Over the years, I have been wishing that I hadn't. I would love to have it. I am in Vermont. Where are you located?
pinktrailer is offline   Reply With Quote
Old 11-18-2010, 10:30 AM   #4
1969 27' Overlander
Gold Hill , Or
I seem to have created a challenge for my self! I had no idea so many might want the antenna. It is a roof mounted unit, it does not have the inside the trailer raising mechanism (it appears that was removed) everything above the roof skin seems to be there and the crank for orienting it is (inside trailer) available. I am stumped as to what to do. I've had three requests for the antenna; are there any who have need of it who might have either trunk latches with key (my unit has no keys for the exterior access hatches) or a round light fixture with the flat round switch knobs (my front interior light was ruined by a leak). I hope I am not creating a larger issue but if a trade is possible with any of you that would be great. Regardless, I will not trash the antenna unit!
Jay
Old 11-18-2010, 12:06 PM   #5
1968 26' Overlander
Jay, No light fixture or latches here. I'm still interested though.
I too had no keys for the exterior hatches. I removed one of the latches and took it to a locksmith. He inserted a blank key into the lock, turned it several times against the tumblers which indented the blank key. He then made me a key that works. All of my exterior hatches are keyed the same.
Old 11-18-2010, 02:21 PM   #6
1967 26' Overlander
1953 17' Clipper
Mendon , Vermont
Oh well.....I will drop out of the running. I thought it wasprobably a front mount, as that is what my 67 had. Thank you anyway. If you can't get your lock re-keyed, the replacement locks are very inexpensive from Vintage Trailer Supply or Inland RV.
Old 11-20-2010, 03:42 PM   #7
1969 27' Overlander
Gold Hill , Or
Jim, here's a link to a series of pictures of the antenna. I also have the insider part of the crank that holds the antenna to the trailer but didn't get a pic of that. Will box it up and send it to you on Monday and send an e-mail note along with shipping costs.
Jay
Picasa Web Albums - Jay - '69 Airstream...
Old 11-20-2010, 09:55 PM   #8
1968 26' Overlander
Works for me -- If you are reusing your appliances, I may have parts you can have. I've removed the original oven, refer, stove top, furnace. All are in poor shape but perhaps parts could be salvaged if you are interested.
Old 02-18-2011, 03:18 PM   #9
1969 27' Overlander
Lehi , Utah
I will remove my antenna this spring and will be up for grabs. I would rather not take it to the dump. I also have a 69 Overlander.
Clay
ClayC is offline   Reply With Quote
Old 03-22-2011, 04:21 PM   #10
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
Clay, have you taken off your antenna yet? If not I will take it. Scott
72 tradewind is offline   Reply With Quote
Old 03-23-2011, 06:13 PM   #11
1969 27' Overlander
Lehi , Utah
I haven't yet but the weather is shaping up so it will happen soon. Keep in touch
Clay
Old 03-29-2011, 12:59 PM   #12
1972 25' Tradewind
Willis , Texas
Images: 8
Ok
antenna, 1969 Overlander, parts, restoration
Looking for 1967 Overlander radio and TV antenna bighowdytex Audio, Video & TV 8 12-17-2015 04:22 PM
Antenna for 1972 Overlander jazz1945 1972 Overlander 6 08-10-2010 02:16 PM
Removed TV Antenna... JK3500 Roof 9 10-22-2008 11:18 AM
Has any one just removed.... tyndalelady Upholstery, Blinds, Walls & Interior Finishes 4 01-26-2006 11:12 AM
antenna on 61 overlander heavyduty Electrical - Systems, Generators, Batteries & Solar 1 04-18-2005 01:20 PM
