Old 08-03-2010, 08:22 AM   #1
TBA
1985 34' Excella
Athens , Ohio
85 Excella roof vent exterior plastic source
I have an 85 Excella 34' with three roof vents with fans and translucent plastic skylight panels.
The portion of the vent which opens has an inner and and outer plastic panel. The outer ones are shot. They are aproximately 1 x 1 foot and are riveted to the aluminum vent cover.
What is the right type of plastic to replace these plastic panels with and where can I source it?
TBA is offline   Reply With Quote
Old 08-03-2010, 08:46 AM   #2
Many owners replace the entire cover, with either a milk white or solar gray cover.
Either one lets in more daylight.
Old 08-03-2010, 09:00 AM   #3
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville , Tennessee
I replaced two of our 3 with FanTastic vents and we are very pleased with the results.
Andy do you guys have the cover noted, that may be a good idea for our middle one.
Thanks, Kevin
NashBuff is offline   Reply With Quote
Old 08-03-2010, 09:04 AM   #4
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Well, I found it pretty quick on your site. How hard is this to install?
Old 08-03-2010, 10:00 AM   #5
Having a cool one at the same time, maybe an hour.
Without the cool one, until finished, maybe 10 minutes.
Old 08-03-2010, 11:56 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I redid my "plastic" with Lexan from Home Depot. Cut to size, drilled holes for rivets, riveted on and laid a bead of vulkem under the lexan as a gasket.
Old 08-04-2010, 06:34 AM   #7
TBA
1985 34' Excella
Athens , Ohio
Thanks for the replies. I will give the Lexan solution a try.
Todd
Old 08-04-2010, 09:11 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
a tip you already may know -If you cut the lexan through blue masking tape it will cut smoothly..using a laminate blade on your saw. Then drill your hole for the rivets.
Old 08-04-2010, 07:54 PM   #9
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
Home Depot has the Lexan in both clear and smoke color. I am in the process of doing the exact same thing to my 86 Excella 34'
_____________________________________________
"I love work, I can sit and watch it for hours."
Al
Archersfin is offline   Reply With Quote
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
Plastic Hinge source for Cerritos built units wlj1943 Cabinets, Counter Tops & Furnishings 11 02-16-2012 02:26 PM
Plastic Bedroom Roof Vent Deterioration 2dabeach Roof Vents, Skylights & Fans 29 07-08-2010 03:38 PM
Replaced roof vent 80 Excella ALANSD Roof Vents, Skylights & Fans 1 06-01-2010 03:39 PM
Source for exterior light, '92 Excella? EA Stein Lights - Interior & Exterior 9 01-29-2006 04:34 PM
