Old 03-24-2011, 09:13 AM   #1
jsapp's Avatar
1987 34' Excella
Bonifay , Florida
2 roof panel questions
1. Is the a/c supposed to drain down the outside?
2. I have several dents/dings/wrinkles on my roof panel in addition to a depression around the antenna mount that is leaking; can the entire roof panel be replaced?
jsapp is offline   Reply With Quote
Old 03-24-2011, 11:10 AM   #2
The AC is supposed to drain thru a drain tube, and not run off the roof.
All exterior sheetmetal panels can be replaced, in the field.
Old 03-24-2011, 11:45 AM   #3
1973 31' Excella 500
Spring Green , Wisconsin
The A/C should have a drain tube. If water is leaking in from the A/C, check to make sure the drain tube isn't blocked.
From what I've read on these forums, most any panel can be replaced but some require a lot more work than others. It may be much less work to remove some of the "wrinkles" unless they are creases by using a dent puller. Take a look at this thread. The area around your antenna may be fixable as well without replacing the panel.
Hopefully, others will chime in with their recommendations.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
New owner had 3 questions LindaM Land Yacht/Legacy Motorhomes 6 05-23-2017 07:23 PM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
Ugh! It's time for the roof. DougZ Roof 7 02-03-2011 06:56 PM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
