Old 01-31-2011, 04:00 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Will gasket material seal the rear bumper storage?
I'm in the middle of replacing a 3' x full width section of the floor in my 1991 limited. Pulled the inside panels off, cut the old bolts off, and now have unfettered access to the leaky bumper storage cover. I pulled it out, cleaned it off and now want to reseal to prevent leaks. I don't want to use vulkem because it will never come out again if need be. I was thinking of using a layer of waterproof gasket material above and below the plate so that when the floor is bolted down the gasket will be pressed into a tight seal. Has this been successful for others?
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-03-2011 11:22 PM
AS280 - Rear airbags bypassed dalefox Classic Motorhomes 45 02-17-2011 05:40 PM
Exterior gasket material? NicheVintage Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-31-2011 08:56 PM
Gasket source for Suburban NT30K furnace? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-13-2011 01:35 PM
Part # Duo therm penguin gasket? HCR Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-09-2011 12:27 PM
