Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Bumpers & Bumper Storage
Old 08-25-2008, 07:27 PM   #1
Profile:  1966 26' Overlander
Conover , Ohio
What is it?
I am restoring a 66 Overlander and I found something I am not sure if I need or not. It is just on the inside of the rear bumper outside the frame rails. It is a verticle tube that is split with an adjuster lever. It looks like a tube will clamp into it, but I am not sure of the use. Any ideas?? Thanks, TomE.
air66stream is offline   Reply With Quote
Old 08-25-2008, 07:32 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I believe that is/was a stabilizer jack. There would have been another piece that would rest on the ground and then this would clamp onto it.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
InsideOut is online now   Reply With Quote
Old 08-25-2008, 07:33 PM   #3
modarch's Avatar
Profile:  1967 17' Caravel
Memphis , Tennessee
I have a pipe just like that only metal on each side of the rear rear bumper and the PO told me that another PO used it to insert poles for a clothesline. If it was up front it could have been a flag pole holder...
modarch is offline   Reply With Quote
Old 08-25-2008, 07:35 PM   #4
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Here is a picture of a complete stabilizer:
(No Longer at Inland RV)
Old 08-25-2008, 07:33 PM   #5
Well-Preserved
We had them on our '63 Overlander.
They are made to hold stabilizer bars. The rod (stabilizer bar) goes through it, drops to the ground, and the clamp holds it from sliding up and down when the trailer moves.
Old 08-26-2008, 01:05 PM   #6
hampstead38's Avatar
Profile:  1967 26' Overlander
Upperco , Maryland
I had a bike rack with a couple of very rotting pieces of 2x4. What is it about using wooden blocks, I wonder?
Web site to be determined.
hampstead38 is online now   Reply With Quote
Old 08-27-2008, 04:23 PM   #7
Conover , Ohio
Jacks make sense
Well, the stabilizer jack makes sense. I don't remember seeing any of the other parts in my pile-o-stuff. I do however have four adjustable aluminum jacks that kind of look like automotive jack stands. I am wondering if the PO may have used these instead of the stabilizers? I will probably leave them off at this point, I can always add them later if I need a little more stabilizing. Thanks, TomE
