Old 07-19-2011, 01:53 PM   #1
grumpy's Avatar
2000 30' Excella
Sun Lakes , Arizona
Rear bumper repair - 2000 classic
Hi all,
I need advice for repair of a rear bumper. It appears the epoxy used in the manufacturing has dried out and the "rub strip" is beginning to fall off. The trailer is a 2000 30' classic. Pictures may be found here:
- Photo Gallery
This is on the left side. My initial thought was to clean thoroughly and reglue. Then I noticed the "rub strip" may be being held up by the screws through the reflector. This gives me another option. I can buy another reflector and put it nearer the right end of the "rub strip". Or I could do both and buy a second reflector for the right side "rub strip".
Any advice is appreciated. IE, for a specific glue/epoxy, do not add any more screws, whatever.
Thanks from Grumpy
grumpy is offline   Reply With Quote
Old 07-19-2011, 02:03 PM   #2
dznf0g's Avatar
Oswego , Illinois
I think, if you clean both surfaces really well and use 3M molding adhesive tape you would be fine. Autos use this type of adhesion with good results.
Old 07-19-2011, 02:25 PM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
3m also makes a great weatherstripping glue that we use here at work. You can get it in black.. coat both sides and let it get tacky and then stick it and its done. Good luck. Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-21-2011, 11:20 AM   #4
grumpy's Avatar
2000 30' Excella
Sun Lakes , Arizona
Thanks guys. I will try to do the repair this weekend and post a pic of the result next week.
Old 04-03-2012, 05:19 AM   #5
JFScheck's Avatar
Rockville , Maryland
Images: 33
Any pics from the repair, which repair did you go with, and how is it holding out?
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
1989 Classic 345LE crazeevw Classic Motorhomes 626 07-17-2019 08:34 AM
Ohana '74 - 1974 Airstream Ambassador Mid-Twin / Rear Bath Trailer Erik Olson 1974 - 1979 Ambassador 21 04-07-2016 04:04 PM
Where did you drive your Classic Airstream Motorhome today? crazeevw Classic Motorhomes 29 04-06-2012 02:32 PM
I have a strong mildew smell coming into the rear Bedroom of my 34 foot classic. Emh142 General Repair Forum 8 04-03-2012 07:26 AM
Rear bumper repair - 2000 classic grumpy Bumpers & Bumper Storage 4 04-03-2012 05:19 AM
