Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Bumpers & Bumper Storage
Old 08-17-2008, 03:40 PM   #1
Mike Leary's Avatar
Profile:  On the move , To Datil, NM
moho bumper replacement
After backing into a number of low riding bandits over the years, I could not
take it any more...Andy got me a bumper, whoa, no holes drilled? After doing
some measuring, I realized all our outfits are "one-off" and holes don't line
up as assembly line products do. So I measured, measured, measured my
trashed bumper, thought about it for about a week, those bumpers will set
you back almost $ 500.00, so you screw it up, there is no getting back, Loretta. Bought brand new 5/8" & 3/4" drill bits, made a bench for my Delta
drill press, took a "Sharpie" pen & marked the holes for the bumper on the
inside & transfered to the outside locations for drilling. Drilled small holes,
re-checked, put masking tape on the drilling area (the glue in the tape helps),
took a deep breath & drilled the tops first. Put the bumper back on to make
sure it was right, put the bolts in to make sure the bottom measurements
were right & drilled the bottom. The bumper guards are less stressfull, though
hard to align because of the curve. The larger holes help align everything.
I would not try this at home without a drill press (I did have to "adjust" one
hole). Not for the timid, but who's timid on this site?
1983 310 Turbo Diesel Mo/Ho "Bess" 212,292 miles
Full timing since 1994
Mike Leary is offline   Reply With Quote
Old 08-17-2008, 07:25 PM   #2
Profile:  Richmond , Kentucky
Nice job Mike! Looks like you got it right the first time!
My mom always used to joke about how my dad would measure something once, cut twice and it would still be to short....... (in really he wasn't that bad )
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 08-17-2008, 08:49 PM   #3
Mike Leary's Avatar
You can imagine how carefull I will be backing in from now on.
Old 08-17-2008, 08:57 PM   #4
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Mike,
Where did you get your new bumper? $500 you said?
guy99 is offline   Reply With Quote
Old 08-17-2008, 09:15 PM   #5
Mike Leary's Avatar
Originally Posted by guy99 View Post
Mike,
From Inland R.V., Airstream had it made & sent it direct. Yup, about $ 470.00.
Old 03-20-2009, 09:44 PM   #6
woodysdad
woodysdad's Avatar
Profile:  1968 22' Safari
1977 31' Sovereign
1977 Argosy 28
Mystic , Connecticut
does anyone know where I might find wraparound bumper ( both front and rear) for a 1976 Argosy 28' motorhome new or used in decent shape , thanks
woodysdad is offline   Reply With Quote
Old 03-20-2009, 10:14 PM   #7
Commercial Vendor
Profile:  Corona , California
We have both the front and rear new bumpers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-21-2009, 06:41 AM   #8
Andy,
Do you have a "limited" supply of these bumpers or do you have a source to have replacements made should your current stock run out?
Just thinking about the future......
Old 03-21-2009, 07:44 AM   #9
Commercial Vendor
Originally Posted by bkahler View Post
Andy,
Those bumpers, we are promised, will continue to be available for the foreseeable future.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-27-2009, 02:06 PM   #10
woodysdad
woodysdad's Avatar
1977 31' Sovereign
1977 Argosy 28
hello again I have a 2 questions? I now own a 77 argosy 28' moho, it has a straight bumper front and back, I was wondering could a wraparound bumper which I have seen on the 76's fit without too much trouble and Andy how much are these bumpers? and secondly will the cast aluminum rear 3 light assembly found on my 77 sovereign fit onto the argosy (if I remove the fibreglas housing assembly) it seems I could surface mount the a/s light onto the argosy rear skin? thanks martin
Old 03-27-2009, 02:17 PM   #11
Commercial Vendor
Venders cannot post prices.
Please check your PM for them.
Yes, the tail light bezel from the 77 will fit the Argosy MH.
You can also update the lights to LED's.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-27-2009, 02:28 PM   #12
Mike Leary's Avatar
Read my post a couple of times if the bumpers come without holes.
Classic MOHO Replacement Battery recommendations zamboni Classic Motorhomes 10 10-30-2007 07:28 PM
69 bumper tracker Bumpers & Bumper Storage 1 06-11-2007 07:59 PM
Hello - new with '91 moho! Spud Member Introductions 4 05-09-2007 10:52 AM
Value of Argosy MoHo? Blu_Hwy_Lady Trailer Values 11 03-06-2007 08:58 PM
Rear BUMPER Replacement clancy_boy Bumpers & Bumper Storage 6 08-24-2006 08:23 PM
