Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Bumpers & Bumper Storage
Old 06-29-2010, 07:27 PM   #1
Bex
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
Is this rear end separation?
Just got the trailer home and have started the process of clean up, sealing and general bits and bobs.
I new there was some water damage in the rear floor only (and only in one small area).
I cut out a piece of the floor, stripped out the rotten bits of ply from under the wall and when I did so, I noticed light coming in from outside.
I jammed my screwdriver through to get the area of the leak from outside.
Is it separation? I would think not because its just one small spot.
If it is, whats the fix?
If its not, whats the fix? Vulkem?
Pics attached.
Bex
Name:	Rearend bumper closeup.jpg
ID:	105963   Click image for larger version
Name:	Rearend bumper perspective.jpg
TAC AB-1
A wise man once told me he wanted to stay fit enough to run a marathon on his hundredth birthday. Another said he wanted to be shot by a jealous husband on his, I'm with the latter. God bless you Richard.
Carpet Cleaning is what I do, it's not who I am.
Bex is offline   Reply With Quote
Old 06-29-2010, 07:28 PM   #2
Bex
Hmmm
My little arrow doesnt show up in the left pic. The pointy thing is the end of my phillips driver
Bex
Old 06-29-2010, 07:43 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Yes.
Probably need to pull the interior panels and check to make sure you have fasteners, that the channel isn't broken and you will need to add some additional hold down brackets to the channel.
Aaron
WBCCI #XXXX AIR #2495
Old 06-29-2010, 09:00 PM   #4
Bex
How do I seal it?
Can you (or anyone else that is reading) point me to an info page or how-to?
Thanks so far
Bex
Old 06-29-2010, 09:54 PM   #5
1965 17' Caravel
Birmingham , Alabama
You can start by checking to see if there are still bolts coming thru the rear frame member. Feel around on the bumper box side or look to see if you can remove some screws and drop a portion of the center bellypan section and take a look. If the bolts have rusted away, you will need to get behind the wall from above to put in new bolts. If the frame has rusted away or the floor rotted, its going to be a project. Better to fix it than just plug it with Vulkem.
gwchitty is offline   Reply With Quote
Old 06-30-2010, 07:50 AM   #6
Bex
Bolts are there and in good condition really.
The frame area that I exposed has surface rust only, not bad at all.
That being the case, would I "just" fill it with Vulkem?
The PO disconnected the water inlet and plugged the hole in the floor so I will be dropping the rear to re-connect it. I shall take a closer look at that time, probably this evening.
Bex
TAC AB-1
Old 06-30-2010, 08:11 AM   #7
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If the ply wood is rotten you will have to cut and replace it. Mine was rotten out on mine. I had to replace the whole rear end plywood which meant taking out the whole bathroom. Good thing i was remodeling.
It's not a fun job but if you don't do it it will cause more damage. Like everyone has said look for some bolts coming down. You have to pull the bottom panels on the inside to get to them. That means drilling out the rivets that hold those panels on. Once you have those off you can get to the channel and put new bolts down through the flooring to suck it back up. You will also need to take the underbelly off to get to that side. It's not a quick or easy job... I didn't detail mine but you can see a picture here
http://www.airforums.com/forums/f327...r-44644-4.html
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-30-2010, 08:17 AM   #8
Chasmorgan's Avatar
1999 23' Safari
This thread may help! http://www.airforums.com/forums/f456...ybe-56674.html
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Rear End Separation-What Years Are Worse dmcinfo Repairing/Replacing Floor &/or Frame 11 11-30-2023 09:56 AM
rear end separation lahrfarm Repairing/Replacing Floor &/or Frame 20 07-10-2010 03:33 PM
Rear End Sag Not Separation airstream74 Repairing/Replacing Floor &/or Frame 44 12-27-2006 09:31 PM
Rear End Separation 76argosy26 Repairing/Replacing Floor &/or Frame 6 09-13-2004 09:32 PM
Rear End Separation Questions... Morning Dew Repairing/Replacing Floor &/or Frame 24 02-03-2004 10:22 PM
