Old 10-04-2011, 07:06 PM   #1
Elliot/Barbara
ElliotA's Avatar
2006 28' Safari S/O
Fort Collins , Colorado
How do you polish the aluminum bumper
My 2006 Safari's bumper is blotchy and I would like to polish it up and clear coat it.
What is the best way to do this procedure?
ElliotA is offline   Reply With Quote
Old 02-23-2012, 03:56 PM   #2
2004 16' International CCD
Orem , Utah
I was thinking the same thing
It would be summer project, use paint remover on clear coat. Then just polish it up or re clear coat. Obviously prep on this area is big concern after polishing. I would use mineral spirts,brake cleaner and like before clearing. I am sure there is clear coat already on there my rag with polish stayed pink no black so it's cleared.
starcraft is offline   Reply With Quote
Old 02-23-2012, 04:03 PM   #3
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Polish or just clean and wax?
I get confused on here sometimes between polishing and waxing. We have an older trailer (84). And the back bumper and storage area was in pretty sad shape with layers of peeling paint. This link will show you what I did. Citristrip for paint removal, mineral spirits to clean up residue, clean and paint up the inside and then finally just a coat of wax on the outside. Have not made the leap to polishing just yet...
http://www.airforums.com/forums/f477...nup-85474.html
Hope it helps!
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 02-23-2012, 10:41 PM   #4
Orem , Utah
Polishing is just that doing real fine scratching of surface say like 2000 grit
Rule to live by is use least aggressive polish that you need. Compound should be outlawed that only worked on old lead paints. Wax on other hand only protects the top layer like sacraficial (yes I can not spell today lol) clear coat. I believe newer Airstreams have aluminum bumpers with clear coat over area. My 04 has few areas that do not look new and one spot with sticker residue. I may unbolt it and strip clear off then polish it up and install.
Old 02-24-2012, 12:48 AM   #5
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 40
Clear Coat?
I've been wanting to buff up both the rear bumper and tail light fixtures on our 2011 FC. Based on what I've read above, I think I'll use a paint remover to clean off the existing clear coat, then polish the aluminum using some 3000 or 6000 grit sanding pads I use for furniture finishing. Maguires or rotten stone might do the trick for a final mirror finish ...
My question: what do you use for the final clear coat, and do you need to prep the surface in any way before applying?
Thanks for the help,
Paul
Those who dance are considered mad
By those who can't hear the music.
Road Geezer is offline   Reply With Quote
Old 02-24-2012, 09:47 AM   #6
Orem , Utah
Lets see picture of 2011 bumper
Seems little new to be messing with it
Old 06-26-2013, 04:12 PM   #7
phughes's Avatar
2011 23' FB Flying Cloud
Tucson , Arizona
We have a 2011 FC with bumper and around tail lights clear coat has discolored. What did you end up doing to clean yours? Paint remover doesn't seem to work.
Don & Patti
phughes is offline   Reply With Quote
Old 06-26-2013, 04:16 PM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you tried citri-strip?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-26-2013, 05:08 PM   #9
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
FYI, I found at Alumapalooza that a number of us with new trailers (less than 2 years old) have pretty nasty looking bumpers. It appears as if whatever they used for clear coat simply did not hold up...at least for the 2012 model year. Maybe the '13's look better, but mine is dull and oxidized. (My trailer is under shelter when it is not on the road, and it has spent very little time close to salt water.)
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-26-2013, 10:56 AM   #10
2019 23' International
Loda , Illinois
I just traded my class A motorhome for an Airstream. The bumper has been discolored, not sure why. I have attached photos. Anyone experience this? Have any suggestions?
ID:	194214   Click image for larger version
Cdusm is offline   Reply With Quote
Old 08-26-2013, 12:23 PM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I used "Southern Shine" on mine. But I don't know if it's still available.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-27-2013, 12:51 PM   #12
Loda , Illinois
Tank you, sir. I will try to find it.
Old 08-27-2013, 02:18 PM   #13
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
My 2011 23FB has the exact same problem. I think one of my first posts on the forums may have been trying to determine what was happening and how to fix the problem. On our AS it is the bumper, the taillight housings, the door hinges, and the grab bar mounted next to the main door. I never did find a definite answer although I did try several suggestions none of which worked. It looks like these posts have zero'd in on the issue......
Landrum is offline   Reply With Quote
Old 08-28-2013, 09:31 AM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
silver paint might be helpful, polishing will not last long
AIR #005
retired!
Old 08-28-2013, 10:38 AM   #15
After I stripped mine, I used a product called
Glyptone, formerly "heavy metal polish"
Used medium abrasive green and sealed with blue. I touch up once annually.
0557 is offline   Reply With Quote
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 06:47 AM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 06:51 PM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 09:08 PM
