Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Bumpers & Bumper Storage
Old 11-10-2008, 07:46 PM   #1
hampstead38's Avatar
Profile:  1967 26' Overlander
Upperco , Maryland
Flimsy bumper storage cover
As part of getting the Overlander to move, I pulled the rather flimsy bumper storage cover. I don't know about others, but I think the entire thing could be a bit more robust. I'm thinking of fabricating a new cover from heavier aluminum and trying to find an aluminum piano hinge... and better tie downs. If anyone has an improved design, please feel free to fere me to some photos. Thanks.
Web site to be determined.
hampstead38 is offline   Reply With Quote
Old 11-10-2008, 08:21 PM   #2
mustang's Avatar
Profile:  1986 31' Sovereign
Kent , Ohio
I just bought a 1989 soverign. It has a very flimsy cover on the bumper storage compartment also.
I had to take a double look at it. I thought it was felt paper for roofing at first
mustang is offline   Reply With Quote
Old 11-10-2008, 08:41 PM   #3
jpeterman's Avatar
Profile:  1972 27' Overlander
Graham , North Carolina
I don't have a solution yet, but I do have the same problem. Hope you or someone does find a good fix.
thanks for the post
Jerry
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is online now   Reply With Quote
Old 11-10-2008, 10:15 PM   #4
bobkelly's Avatar
Profile:  2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Twofer Opportunity
When you decide to replace the wimpy cover plate over the bumper storage area, consider increasing the volume of that storage area at the same time.
My trailer is not available for a photo op, but here is a verbal description. After removing the existing lid & hinge, an aluminum box without a bottom was fabricated out of .08 inch thick sheet. The width and depth matched the opening of the bumper storage box without it's lid. A 3/4 inch return flange on all four sides provided the faying surface for mounting the box. Both rivets and silicon caulk were used. The height of the box was limited in my case to about 7 inches so as to stay below the heat exhaust vent on the rear of the 22ft CCD International. The lid for this box is the same sort of cover we get on a shoe box. A piano hinge attaches it to the box across the back and two latches secure it on the front side. A separate tab is used to provide for a pad lock.
This doubled the volume and allows for storage of all the stuff I use outside the trailer. This box weighed about 8 lbs. Very happy with the results and it looks like it came this way from the factory.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 11-10-2008, 10:16 PM   #5
cameront120's Avatar
Profile:  1972 25' Tradewind
The lid on mine isn't sheet aluminum but, rather, a thicker piece of extruded aluminum and a full length piano hinge. I'll have to try and take a photo of it tomorrow. The think I dislike about it, is that it isn't water tight. After heavy rain, I get a fair amount of water in the bumper compartment.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 11-11-2008, 07:08 AM   #6
Profile:  1973 27' Overlander
Space Coast , FL
So, it's just like an insert - that fits inside the original box but is 7" taller?
Sounds like a really neat idea. Can you share what type of place fabricated this for you? Just a metal shop?
funkill is offline   Reply With Quote
Old 11-11-2008, 07:33 AM   #7
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Sounds like the one on mine. I get very little water in mine, maybe it's an Arizona thing.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-11-2008, 10:10 AM   #8
That's exactly the same as mine, Richard. Thanks for posting the picture and saving me a trip outside in the pouring rain (must be a vancouver thing)!
The only thing missing from mine, is the little 'hold-open' to the right. When convenient, would you be able to take a closer picture of that? I'd like to see if I can fabricate something similar.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 11-11-2008, 10:13 AM   #9
bobkelly's Avatar
Funkill----Insert is a good description, but I didn't drop it into the existing cavity. Using the picture in post #7, the flanges on the bottom of the new box turn inward so they are not visible and rest on the top lip of the rear bumper and the top flange of the two longitudinal frame members. It was fabricated in a small metal shop in Newport, Oregon whose owner liked the idea of cooking up something a little different. The bead of caulking makes mine water tight around the base and the lid overlaps down the sides about 3/4 inches and makes it very stiff as well as water tight. Hope that helps
2003 22ft CCD Int'l
WBCCI #2960
Old 11-11-2008, 10:20 AM   #10
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
Our 67 also has a somewhat thicker cover, not flimsy at all. The only thing I did for it was to purchase a new piano hinge. (Get a marine-grade hinge from any of many online marine places.)
Lynn
WBCCI 21043 | Blog
Monte Verde RV Park & Campground: 50% WBCCI discount
Angel Fire, New Mexico
Old 11-12-2008, 07:05 AM   #11
Space Coast , FL
Thanks for the details Bob. In your first post, I missed the "an aluminum box without a bottom" portion. Now I understand.
Old 11-12-2008, 09:27 PM   #12
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
The bumper compartment on our Bambi is always taking on water when it rains or it gets washed. Makes me crazy. The box does have drainage holes in the bottom so it never stays too wet too long, but still...that's where we store our shore line electrical cord and surge protector so I'd rather it not get wet so easily. I have been thinking about putting some weather stripping around the underside of the lid to help keep water out, and then spraying the inside of the compartment with that rubberized tough-hide stuff like they use on pickup beds to help it better resist rust, etc... I think someone on the forums has done this coating treatment before...
TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI F
our Corners Unit #3954
Décor Site: AZBambi Décors
Old 12-15-2008, 02:03 PM   #13
Profile:  2005 22' International CCD
Woodland Park , Colorado
Bob,
just saw your post here and think that is just the ticket for my trailer as well. great job! did you secure the box to the skin of the trailer also or just the bumper? if not, did you leave a gap between the box and the skin? if you ever happen to get pictures of the box please post. jk
JK3500 is offline   Reply With Quote
Old 12-15-2008, 06:09 PM   #14
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
Where is 2air.. There was a tread where someone did a 6 inch extension with the bumper and did a really nice job I will try and look for it. But I am no 2air.
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Bumper Storage Compartment LHall Bumpers & Bumper Storage 11 08-25-2007 04:56 PM
Need picture of bumper storage please jgouras 1959-69 Tradewind 11 03-22-2007 11:47 PM
Bumper storage compartment BillTex Bumpers & Bumper Storage 5 01-23-2007 04:27 PM
rear bumper/storage. rebel beck Bumpers & Bumper Storage 5 02-08-2006 08:19 PM
Rear bumper storage tray Ed Keyes 2004 Classic 9 10-02-2005 09:50 PM
