Old 04-12-2014, 05:02 PM   #1
Drag wheels instead of steel drag bars under bumper?
Has anyone removed the steel rear drag bars with a wheeled drag.
rveillette is offline   Reply With Quote
Old 04-12-2014, 05:39 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Mine are smashed and ground to nubs. Thinking of remaking them. I personally think wheels are an exceedingly bad idea.
Old 04-12-2014, 06:13 PM   #3
When the drag bars are worn out, that tells you they did their job.
Replacing them is the best thing to do.
The worst thing to do is install drag weels.
Most every time someone has done that, they will damage the rear quarter panels when the trailer rides the wheel or wheels, the very first time.
Old 04-12-2014, 06:33 PM   #4
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Originally Posted by Inland RV Center, In View Post
When the drag bars are worn out, that tells you they did their job. Replacing them is the best thing to do. The worst thing to do is install drag weels. Most every time someone has done that, they will damage the rear quarter panels when the trailer rides the wheel or wheels, the very first time. Andy
I agree with Andy.
I bought a 77 Soveriegn with drag wheels installed. One wheels was broken and both rear quarter panels rear crushed. I removed and replaced the axles which increased the ride height by 3-4 inches.
desertair27 is offline   Reply With Quote
Old 04-12-2014, 07:58 PM   #5
1981 31' Excella II
New Market , Alabama
Personally I try not to drag my tail. So far I have done it once.
Perry
Old 04-12-2014, 09:36 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
For a trailer made to "boondock", Airstreams sure ride low.
I try not to drag too but when even many gas stations are too abrupt,,,
Well, I am raising mine 2 or 3 inches when I get new axles.
I have a little land in the south of the state that I want to be able to park on someday.
I agree about the wheels. The wheels will imply license to drag, and cause a person to get careless.
I think I want magnesium drag plates....
Yep, those would be awesome!
Old 04-13-2014, 07:16 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I am not an engineer... at least not a certified one
However I would surmise that the wheels create a point load that puts stress on a specific place. The skids spread the load out over a wider area reducing the chance of damage.
Aaron
WBCCI #XXXX AIR #2495
Old 04-13-2014, 07:22 AM   #8
1981 31' Excella II
There are plates you can get that will allow you to raise the axles and getting a shorter trailer always help.
Perry
Old 04-13-2014, 09:05 AM   #9
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Is there just one style? Just curious as neither of my trailers have them and I'd like to add some on the 33'er when I build the new chassis. I'm picturing a handle shaped loop of steel bar bolted or welded on but thought someone might have a picture to hand.
On snow skis for the twin otters we used to add 1/4" Tyvar and steel bar on to the surface before they went out to cut down on damage, maybe something designed to wear away would help?
truckasaurus is offline   Reply With Quote
Old 04-13-2014, 09:13 AM   #10
All that needs to be done, is install flat plates, maybe 1/4 to 3/8 inches thick, where the frame drags at the rear.
Tack weld them in place, so that they can easily be replaced when they are worn out.
Old 04-13-2014, 12:26 PM   #11
dznf0g's Avatar
Oswego , Illinois
I figure that if and when the bent over "L" in the OE skid gets thin, I'll just tack a piece of 1/2" angle to it and move on. When it gets thin, just do the same.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 04-13-2014, 12:40 PM   #12
1981 31' Excella II
If you have rear end separation a bottoming out situation will crush the rear of the trailer as the loose frame slams into the c-channel and causes the skin above to collapse.
Perry
Old 04-13-2014, 12:53 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I see the ability of drag wheels allowing a trailer to keep moving when a trailer with drag plates would be stopped in its tracks as a danger of drag wheels, unless of course the forced stop is across active railroad tracks...
Stainless steel screws instead of rivets? Lothlorian Ribs, Skins & Rivets 33 03-22-2011 11:22 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Backing up steep driveway-wheels under rear bumper? Wexus Off Topic Forum 12 03-16-2006 08:15 AM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 06:54 AM
Can you guess which rally had Airstream "drag racing?" yukionna WBCCI Rallies & Events 9 08-27-2003 07:42 PM
