Old 11-04-2010, 01:37 AM   #15
Maniacal Engineer
barts's Avatar
Menlo Park , California
When I repaired the rear end separation (sounds painful) on our Tradewind, I replaced the sheet steel separating the bumper storage
compartment from the belly pan with stainless. The top portion that supports the hinge for the access lid no longer goes underneath the plywood, since that brought the water in contact w/ the wood; instead, there's a 5 foot piece of aluminum angle that's bolted to the frame, with a half inch gap to allow any rainwater to drain into the storage compartment. It always got wet, anyway, and there are ample drain holes to prevent any water from accumulating...
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-04-2010, 02:44 AM   #16
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I cleaned ours then primed/painted the frame and exposed pan as well as the top U support. The edge between the pan support/U support and belly/upper sheet were re-caulked. All of the exposed bolts (ground tie down, exterior faucet, bumper bolts, etc.) were replaced with stainless. The insulation replaced. Then on the underside of the lid - 3/4 D gasket on the rear, 1/2 on the sides and 3/8ths on the front edges - that stopped water and dirt from getting into the area.
Old 11-04-2010, 06:18 AM   #17
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Pretty Inside
Not sure my bumper storage drawer is pretty inside, but I did take it to the local lineX dealer several years to have it sprayed with their non skid bed liner. It always looks clean and I have no rust.
fltlevel510 is offline   Reply With Quote
Old 11-04-2010, 06:39 AM   #18
2008 19' International CCD
Spring , Texas
We store our 30A shore power cord; 30A extension cord; wooden blocks for the jack;awning tool and some wrenches. Not to hijack the thread, but does anyone ever padlock it when traveling or storing?
Ed
eleighj is offline   Reply With Quote
Old 11-04-2010, 06:55 AM   #19
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Ed
Yes, We have a padlock on one side
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 11-04-2010, 07:24 AM   #20
Ottawa , ON
Originally Posted by WILDRTEXAS View Post
just because...it better when its pretty too.
When I had the waste tanks' frames and metal boxes re-worked, the fabricator also cleaned up the inside of the box, spray-painted it silver, and replaced the leather "washer" that the electrical cord passes through.
The "washer" is that thing that is made of leather cut in a circle, and the hole is just cut in radial lines around the circle. I realize now that it couldn't be leather, it must be some kind of vinyl, since it keeps it's shape even when it's wet.
And of course, do not forget to caulk where thehorizontal top of the "trunk" meets the vertical wall of the TT, so rain and road slop won't leak in there and mess everything up again...
Any chance of a photo update, Cynhia?
ďCourage is being scared to death, but saddling up anyway.Ē
Old 11-04-2010, 08:27 AM   #21
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from Ga. . .I'm in the wet, dirty and smelly group (I've been worse places),but I don't put any thing in worth stealing. Seems like mine might be pretty easy to get in to. And no point in pretty, IMO., regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 11-04-2010, 09:11 AM   #22
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
When additional storage space opens up it is quickly filled. Always appreciate new places to put 'stuff'.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 11-04-2010, 10:17 AM   #23
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Well, Well..that explains it, my TT came to me from Ga.
I love it there. BEAUTIFUL but it rains too much for me. Dont mind being wet but dirty and smelly...NOPE.
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 11-04-2010, 10:28 AM   #24
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
There are different types of bumper storage—one kind is a drawer. I have seen one where side brackets came apart and the drawer had to be removed until it could be fixed. That means one should check it from time to time to make it is secure and doesn't fall out. There's probably a weight limit for that type (or any type for that manner).
I have a lid on mine, no lock. We leave the exterior power cord there since it came that way plus an adapter for 50 amps.
Gene
Old 11-04-2010, 10:37 AM   #25
dznf0g's Avatar
Oswego , Illinois
Ok. Ok..It seems that IS the place for all the stuff I never knew where to store. How about this question...what have you done to make your bumper trunk pretty inside
The mat which came with the trailer is a mess, and a bat idea. Holds water under it and starts to rus the galvanized steel. I removed mine, cleaned and sanded well and sprayed Rustoleum Truck Bed Coating. Not as thick as spray bedliner, but so far holding up well.
Old 11-04-2010, 11:02 AM   #26
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Now we are talking about decor ideas for inside the bumper?
Mine is decorated with old mouse turds...
cclarkego is offline   Reply With Quote
Old 11-04-2010, 02:33 PM   #27
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
If I had to live it a cardboard box it would be decorated with wallpaper and curtians...Im just saying..
Old 11-04-2010, 02:59 PM   #28
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
We got into ours, emptied it, and swept and washed it, then painted everything oil based metallic silver to protect against rust.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
hoses, bumper
Bumper Storage Compartment LHall Bumpers & Bumper Storage 16 06-18-2015 02:26 PM
Bumper Storage - Any Thoughts Ganglin Bumpers & Bumper Storage 1 06-29-2009 09:12 PM
Need picture of bumper storage please jgouras 1959-69 Tradewind 11 03-22-2007 10:47 PM
Bumper storage compartment BillTex Bumpers & Bumper Storage 5 01-23-2007 03:27 PM
rear bumper/storage. rebel beck Bumpers & Bumper Storage 5 02-08-2006 07:19 PM
