Old 04-13-2013, 07:19 AM   #1
1965 28' Ambassador
Bloomington , Illinois
Clear Coat Stripper products.....
The Napier Removeall 220 is no longer available? Any other suggestions. Vintage Airstream had a replacement product. Has anyone tried it and does it work as well as folks thought the Napier Removeall product worked? Thanks in advance
Jane
janetuck is offline   Reply With Quote
Old 04-13-2013, 08:15 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Citristrip from Home Depot
Citristrip 1-Qt. Safer Paint and Varnish Stripping Gel-QCG73801T at The Home Depot
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 04-13-2013, 12:28 PM   #3
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I'm using the CitriStrip on my Argosy exterior. Works great on everything except the banana wraps. Whatever they used for etching primer is as tough as nails! For a "hotter" stripper, O' Reily Auto Parts sells a really good aircraft stripper.
Phrunes is offline   Reply With Quote
Old 04-13-2013, 02:10 PM   #4
1986 31' Sovereign
Miami , Florida
I really like the Citri-strip. Had to do mine in the side yard and it didn't harm the lawn or me. Had to reapply in some spots but, overall, the plastic coat came off without a struggle.
Mike
Old 04-13-2013, 08:22 PM   #5
1965 28' Ambassador
Do you paint the Citri-strip on and then wash it off with the power washer or do you have to scrape it? Thanks for all your advice!
Old 04-13-2013, 08:38 PM   #6
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Brush on pressure wash off. I'm using a scotchbrite pad as well, but ill be polishing afterwards.
Old 04-21-2013, 10:38 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
So you don't necessarily have to scrub? How long did you leave the Citristrip on before you washed it off? If I'm going to "paint" the roof with white elastomeric coating do I need to strip it too (hmmm, answer my own question: yeah). Looking to do this in the next few weeks.... Thanks for any and all advice!
Kay
Old 04-21-2013, 10:58 AM   #8
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Kay
Kay,
Leave it on for about 20 mins. Just don't do it in direct sunlight as that seems to dry out the stripper and render it mostly innefective.
Matt
