Old 01-26-2015, 07:59 AM   #1
1986 27' Sovereign
Nixa , Missouri
Images: 21
Bumper & tongue refinish
Im getting ready to check this off my list. The bumper & tongue have several layers of caked on paint from the PO. Im planning on having it media blasted (with special care to blast only whats needed) down to bare metal then primed/paint or use the POR 15 products and put it back to a silver or gray color. I initially thought the door was painted to match the bumper but as it is really flaking away now it looks like it may have been a polished stainless steel. I had trouble posting pics previously will give it a shot here.
Name:	bumper right rear 1.jpg
ID:	231156   Click image for larger version
Name:	Bumper right rear 2.jpg
bweldon is offline   Reply With Quote
Old 01-26-2015, 08:07 AM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
If your intention is to paint the tongue and bumper, check out the Bronze spray paint at Lowe's. The Bronze paint I am speaking of is in the storm door aisle. It is the paint for storm door and windows. I used it and am very happy with the results of color and finish. I am not sure why the spray paint is not in the spray paint aisle but, I found it! good luck with your project. Let's see some pictures when done, OK?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 01-26-2015, 08:41 PM   #3
1986 27' Sovereign
Nixa , Missouri
Images: 21
Airdreamers,
Thanks for the response. Is the bronze paint you mention what you have on the tongue of yours in the profile pics? It looks gray/charcoal in color. I don't think I worded my question very well after going back and reading it. I'm wanting to know if the door on the bumper is stainless steel or painted to match the rest of the bumper.
Barry
Old 01-26-2015, 08:52 PM   #4
1976 Argosy 26
Houston , Texas
If your bumper door is factory its aluminum. I striped mine and polished it.
Same with the bumper !
wzelkins is offline   Reply With Quote
Old 04-14-2015, 07:08 AM   #5
1999 28' Excella
New Orleans , Louisiana
I have a 1999 Excella that I would like to repaint the bumper. It is a dark charcoal gray. The paint seem to be worn away and not peeling.
What kind of paint would work?
badkat is offline   Reply With Quote
Old 04-14-2015, 07:53 AM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
There's lots of information here about various sources of paints that are very close and available in spray can for small touch-up jobs. If you're going to do a complete do-over exact matching isn't that critical. Take a piece with the color needed and any good automotive paint supplier ( or if you have a friend with a body shop) should be able to mix you a matching small batch. Be sure and get it in single stage so you don't need to mess with clear coat. Good auto paint " Ain't cheap" but you'll be forever happy with the finish job.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-14-2015, 09:19 AM   #7
1999 28' Excella
Very helpful..thanks!
Old 04-14-2015, 09:23 AM   #8
dznf0g's Avatar
Oswego , Illinois
I can't find my old thread of my redo, but I used (wish I could remember the type....epoxy?) automotive paint and I did clear coat as well. After sandblasting. I did the Hensley as well.
True, not cheap paint, but still looks shiny and fresh after 4 years. I do get an occasional stone chip, but touch up paint keeps the rust at bay.
-Rich-
Old 04-29-2015, 09:18 PM   #9
1986 27' Sovereign
Nixa , Missouri
Images: 21
I finally got around to finishing this up. I will post pics as soon as I can get them loaded. I had the tongue & tail blasted down to bare metal, then primed, then painted the tongue/tail as well as the wraps all the same color.
Airdreamers, I did not find the paint you were referring too but I did find a color that I thought was appropriate. It was the Rustoleum Metallic "flat soft iron". We will see how it holds up to some abuse and elements. I paid a great deal of attention to my prep so I am hoping it will wear well. Beware , this paint is very frustrating to use. It took about 7 cans to do 3 coats, probably 4 of which wouldn't spray unless I held them upside down, which was frustrating at times trying to get the right angles in tight spots. To complete this project I need to replace the plastic piece the connects around the sewer attachment. It is kind of a filler piece between the pipe and the bumper. I lost this piece in the process of blasting and stripping the paint off the bumper. It was very brittle and just fell to pieces in the process. It looks like I would need to remove/unscrew the piece where the hose would attach to be able to install the filler piece. Any idea how this comes off? I'm thinking it may b glued on as it doesn't seem to want to turn.
Old 04-29-2015, 09:21 PM   #10
1986 27' Sovereign
Nixa , Missouri
Images: 21
Sorry, this should say "filler piece between the sewer attachment and the frame". Its kinda hard to see in the pics. I'll try and get a better pic.
Old 04-29-2015, 09:40 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The 'coupling' end you reference, the white one in the picture, should probably be glued on..
Peace and Blessings..
Channing
WBCCI# 30676
POR-15 on tongue and bumper? Airwave503 Repairing/Replacing Floor &/or Frame 6 08-08-2014 09:18 PM
28' Airstream Motorhome -Engine Rebuilt & Int.Refinish eBay Watch Airstreams on eBay 0 05-25-2009 04:00 PM
Toned down paint for '63 Bumper and Tongue? Zstream Clearcoat, Exterior Paint & Trim 2 09-11-2008 07:32 PM
Best color paint for '67 frame, bumper, tongue? Stella Clearcoat, Exterior Paint & Trim 12 02-17-2008 08:40 PM
Correct color of bumper and tongue gmc70 Clearcoat, Exterior Paint & Trim 2 06-24-2002 06:19 PM
