07-31-2017, 09:53 AM
1964 22' Safari
Tulsa
, Oklahoma
Why you might want to remove the belly pan
My two day axle job was looking more and more like a belly pan replacement - broken rivets, loose sections, corrosion holes.
I'd considered just putting the axles back on and leaving the pan repairs for a later date.
Glad I didn't. 51 years of rodent homes and dirt were under there. A forty pound garbage bag that would have stunk and would have ripped out the pan entirely during the next rain-drive. The good news is that the underlayment and the frame are in good shape - I guess the rodents took OUT most of the fiberglass and made homes elsewhere.
Lesson is: don't ignore it, it will only get worse.
07-31-2017, 10:17 AM
1969 25' Tradewind
Somewhere
That looks eerily similar to a picture I have after pulling my belly pan a couple months ago! Nasty stuff.
Taking it off isn't that bad of a job, putting on a new one could be interesting for you. I'm lucky (or unlucky) enough to have the frame flipped over on my rotisserie.
07-31-2017, 10:25 AM
1967 17' Caravel
Oak Creek
I did mine on my back on a creeper. I cut the new from the old patterns. Put it on in 2 strips as it was done originally.
I cut 2x4 wood pieces to prop it up to drill then Clecoed it in place.
The worst part is how hard it was on my shoulder, all the drilling with very little room for leverage.
Good luck with your project!
07-31-2017, 10:29 AM
1967 17' Caravel
Oak Creek
forgot I used a step of plywood side to side to hold it as well.
07-31-2017, 12:14 PM
Rivet Polisher
1973 31' Sovereign
Mt Pleasant
, North Carolina
I found the same when I removed mine, I didn't bother to put it back on, makes it much easier to get to plumbing and wiring!
-Jim Pantas
1973 31 ft Sovereign
2009 Chevy Express 3500
07-31-2017, 12:25 PM
TinCan
2016 30' Classic
Apache Junction
What do you suggest to prevent this from happening? Continual cleaning?
TinCan
07-31-2017, 02:46 PM
1967 17' Caravel
Oak Creek
Keep the rodents out will help tremendously. My 67 had gaping
07-31-2017, 02:52 PM
1967 17' Caravel
Oak Creek
Sorry hit send.
Gaping holes around the propane lines and the sewer connection. These are fixed with the new belly pan.
They can also enter through the tongue of the trailer & at the slots for the steps to slide in and out on.
I made removable covers of aluminum for all these problem areas.
07-31-2017, 03:05 PM
1964 22' Safari
Tulsa
, Oklahoma
Maybe don't leave it in the woods? LOL
07-31-2017, 06:21 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Why re-install it?
Can't reach anything with it installed, and is the aerodynamic drag that much worse?
07-31-2017, 07:02 PM
1966 24' Tradewind
Kansas City
, Missouri
Originally Posted by MelGoddard
Why re-install it?
Maybe to keep the underside of the subfloor dry? Wouldn't it get pretty wet driving down the road in the rain?
07-31-2017, 08:07 PM
2011 30' Flying Cloud
East Jordan
, Michigan
Suggest replacing belly pan, omit the fiberglass batt nest material. Cork floor is decent insulation and warm on the feet.
07-31-2017, 09:57 PM
1992 29' Excella
Virginia Beach
, Virginia
Thanks for this thread, I have a 29' 92 Excella, I'm thinking about removing the old belly pan. I want to check the frame, water tanks, etc. After seeing your pics, I especially want to do this.
For those who've done it where did you find your replacement aluminum, what gauge is it and what was the cost?
My existing belly pan has a ripple like crimping on the overlapping edges. Does anyone know how that's done and why?
Also, currently I'm on an unfinished wooded lot. The ground slopes etc. making it much closer to the ground at the front end. So close, I can't get under it and keep it level. I'd love suggestions on how to elevate the entire body, so I can work under it. We're full-time BTW, so living in it as well.
Pete
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
08-02-2017, 09:48 AM
1964 22' Safari
Tulsa
, Oklahoma
Pete
I was considering these guys because they could do longer pieces.
http://www.airpartsinc.com/1800_5052..._other_RVs.htm
08-03-2017, 06:10 AM
Rivet Polisher
1973 31' Sovereign
Mt Pleasant
, North Carolina
Pete
I found a local metal fabrication shop that could get .032 aluminum which is what I used for the spots I repaired.
You'll want to add some strength to the aluminum with a bead roller:
http://www.northerntool.com/shop/too...0089_200660089
I had some leftover 12 ton jackstands from a previous job I did so I used them to raise it up high enough so I could fit underneath.
Here is a pic of all the rat poop we found in our belly pan when we pulled our rotten floor up.
-Jim Pantas
08-08-2017, 09:02 AM
1992 29' Excella
Virginia Beach
, Virginia
Thank you, I see where others have used them as well. And thanks for for starting this thread.
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
08-08-2017, 09:04 AM
1992 29' Excella
Virginia Beach
, Virginia
That's one discussing picture. Hahaha
Thanks for pointers and the link to the bead roller.
Pete
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
