Old 12-06-2010, 08:26 PM   #1
uncledan's Avatar
1966 17' Caravel
College Station , Texas
When should belly be replaced?
How do you know when your belly is bad enough to need replacing?
I was crawling around on my own belly which has its own issues, under our recently adopted 66 Caravel when I noticed some exposed fiberglass insulation and some rivets that had obviously given up. The belly has several areas where it has been patched in the past.
How bad should it get before replacement is considered?
ID:	116671   Click image for larger version
uncledan is offline   Reply With Quote
Old 12-06-2010, 09:19 PM   #2
Ottawa , ON
Looking at the photo of your TT in your avatar, your axles look to be badly shot to me. That could account for the rivets that are pulled out. Look around your TT and see if you are missing other rivets, inside, for example on the ceiling and walls. Your rig looks nice though, a real keeper!
Bad axles are hard on your trailer and will hurt it. Be thankful yours only has one, less $ to replace it!
When you have the belly off (yep, it looks shot, too) have a real good look at the frame and make sure all is well with it too. You won't want to take the belly off a second time if it isn't...
ps: when replacing it, make sure you get the proper rivets, they have a much bigger head and look rather like tiny li'l mushrooms.
Old 12-07-2010, 11:14 AM   #3
uncledan's Avatar
1966 17' Caravel
The axle replacement is on my to do list.
Should the belly be replaced before the axle or the other way around?
Old 12-07-2010, 11:17 AM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I would take the belly pan off, then replace the axle, then put the belly pan back on. Be glad you have a nice short trailer. I shouldn't be too hard!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-07-2010, 12:30 PM   #5
uncledan's Avatar
1966 17' Caravel
It probably shouldnt be but I have a talent for making the simple way complicated
Old 12-07-2010, 02:35 PM   #6
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Uncledan, if you would like some help with that project, I'm just down the road in Round Rock and have lots of free time.
TX-16
Dave Park is offline   Reply With Quote
Should these tires be replaced? SnoSheriff Tires 10 07-20-2009 08:12 PM
Replaced Axles Dieselgrin 1970 - 1973 Sovereign 17 11-15-2008 05:17 AM
Replaced Valances GoldFever 1990 - 1993 Excella 18 06-05-2008 08:19 PM
Replaced Voyager--what to do with it? Kistler Our Community 7 01-19-2004 05:28 PM
How many axles replaced Jabba Axles 7 10-21-2002 01:21 PM
