Old 07-06-2003, 02:48 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
What's this - underneath
I've been wondering, there's this thing hanging down under the trailer, in back, in the middle, near the black tank cap. It's roughly under the shower I guess, which should be a clue. Looks like a big upside down fiberglass hat. What the heck is it?
Stephanie
Old 07-06-2003, 03:01 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
What's this - underneith
Greetings Stephanie!
I am just guessing, but my suspicion is that it is a cover used to protect the "P" trap in the drain line for the shower. I don't believe that it is original; but the "P" trap is one of those troublesome components to replace on a Vintage coach that often leaves a portion of the trap exposed below the belly skin.
Kevin
Kevin D. Allen
AIR #827
Old 07-06-2003, 03:46 PM   #3
airstreamcaravel's Avatar
What is it?
Steph,
My Caravel has the same thing ... It does cover the trap for the shower.
DMC
airstreamcaravel is offline   Reply With Quote
Old 07-06-2003, 05:13 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Thanks, I wondered about it everytime I was down there messing with the sewer :-)
Stephanie
Old 09-05-2003, 08:27 PM   #5
vegas73globetrotter's Avatar
Kevin, you mentioned getting rid of the trap, does that help with the draining of the shower? I've got a 73 globetrotter and black water backs up in the shower as well as anything down the kitchen dran.
Jesse
vegas73globetrotter is offline   Reply With Quote
Old 09-05-2003, 08:53 PM   #6
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Jesse,
If you have black water backing up into the shower I have a question. Do you have the black tank valve open but the sewer cap on? If so the reason that you are getting black water in the shower is because the black tank is full to a level as high or higher than the floor of the shower. The filling of the black tank with grey water this way is a reccomended way to use the kitchen or shower, but capicity is limited.
On a 73 I do not think you have a gray tank.
If you are getting black water in the shower with the dump valve closed then I would suspect the valve is a leaker.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-06-2003, 01:00 PM   #7
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Ah, the old "There's s**t in the bathtub." scream from the better half I hear on the first trip out of the season. There is only one holding tank on my 67 Trotter and a quick look at the drain piping will show you that if the valve is closed you won't be able to fill the tank, only the tub which is the next lowest space. I think only the toilet goes directly into the holding tank, so if the valve is closed it's not s**t, only drain water. Maybe an"open the valve, dummy." sign on the kitchen faucet might be what I need. Tom
Tom Nugler is offline   Reply With Quote
Elastomeric paint smallfry Interior Restoration Forum 4 11-29-2003 03:39 PM
310 MH underneath rust Andre Baillargeon Airstream Motorhome Forums 2 09-26-2003 02:00 PM
2004 Safari JodynJeep 2004 Safari 4 09-01-2003 10:14 AM
Caulking underneath? Kistler Our Community 2 07-10-2003 07:25 AM
darwins theory of camping! john hd Off Topic Forum 20 03-11-2003 04:36 PM
