Old 10-17-2016, 02:43 PM   #1
1978 28' Ambassador
Elk River , Minnesota
What is this??
Hi all,
We have owned our 1978 28' Ambassador for 3 months now, and we have most of it figured out, thanks to all of you!
HOWEVER, there is a square drop down in the belly pan underneath the front living room. I don't want to make my poor, PATIENT hubby open this up to see what is in it, so I'm hoping some of you might know.
It is not the fresh water tank, or grey/black tanks.
It has no openings. There is nothing above it in the camper, but the living room floor. It is not mentioned in the owner's manual, and we don't have a repair manual.
Approximate measurements are 17" x 34" x 3-3/4".
Help!
ID:	273662   Click image for larger version
tpfleg is offline   Reply With Quote
Old 10-17-2016, 02:50 PM   #2
Long Island , New York
Welcome to the forum! There may be an owner's manual available online. I will R&D when I get back home later. Are all four vertical faces the same, showing only aluminum (galv. steel?), with no fasteners other than rivets and the dark bolts holding the box up?
Any chance there was a propane floor heater added at some point, which was later removed when the floor was re-done? Any way of contacting previous owners?
Peter
OTRA15 is online now   Reply With Quote
Old 10-17-2016, 03:50 PM   #3
I believe this spec. sheet covers your 1978 28' Ambassador. Check at the bottom of the middle column, where your model is mentioned under the space heater text. Do you have a separate space heater near an exterior wall? (which would probably not be the one I guessed about under the floor).
https://www.airstream.com/wp-content...89bb08ceff.pdf
If you want to look for other manuals, go to the AS company site:
and click on Service, then either Document Archive or Manuals in the drop down menu.
I did not look very hard, so there may be a more detailed manual available.
Good luck!
Peter
PS -- Any chance a previous owner installed a floor safe there? Stranger things have happened IMO!
Old 10-17-2016, 04:29 PM   #4
Gainesville , Florida
Is it accessible from above? Or just from underneath? If above it might be a safe as was mentioned, or from below a smuggling hole.
Old 10-17-2016, 04:35 PM   #5
I wondered about smuggling too but thought it was too visible. Curious to hear her answer about the other three vertical faces being just the same, or not?
PS -- Bingo! ??? Right inside the entry door, was there a removable grate inside the door for scraping one's feet off, and the metal box caught the droppings?
A grate idea!
Old 10-17-2016, 05:52 PM   #6
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Curious me, I would unscrew 3 sides and see what is inside. At the least.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 10-17-2016, 06:16 PM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Finally! Someone found DB Coopers stash!!
1990 35' Silver Streak
2004 555 Cummins
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 10-17-2016, 07:40 PM   #8
1988 Argosy 32
Lomita , California
Beer tank ?
Wolfe is offline   Reply With Quote
Old 10-17-2016, 07:46 PM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Ah, come on Terry...don't keep us guessing - just grab a screw driver, crawl on under there and unscrew the screws & let us know what you find! There only appears to be 16 of them...I know you can do it, no need to wait on the hubby for this one.
Shari
Old 10-17-2016, 07:57 PM   #10
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Considering that it's attached to the belly pan I'm guessing that someone built a better mouse trap.
Al Boondy is offline   Reply With Quote
Old 10-18-2016, 09:39 AM   #11
1978 28' Ambassador
Oh my gosh!!! You all are hilarious!! What a great laugh with my morning tea!
I, too, thought of a secret stash of cash!
Unfortunately, Dear Hubby put in new flooring, so I WILL have to go at this from underneath.
No, there was no electric heater that I could find.
Peter, thank you for info on how to get more info! I am a librarian and do research for a living, but this one has stymied me!
Alright, I'll let you guys know what I find out!
Old 10-18-2016, 09:57 AM   #12
batman's Avatar
1964 22' Safari
modesto , California
Curiouser and curiouser.
batman is offline   Reply With Quote
Old 10-18-2016, 10:04 AM   #13
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Flux Capacitor
Old 10-18-2016, 10:09 AM   #14
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
I still find it amazing that a flux capacitor comes in so many different shapes. ;-)
