Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 09-17-2009, 07:53 PM   #1
gutsgolf's Avatar
Profile:  1972 31' Sovereign
Alexandria , Louisiana
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
What is the best way to hold the insulation in the belly
How is the best way to hold in in place while you put belly skin back in place.
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
gutsgolf is offline   Reply With Quote
Old 09-17-2009, 08:00 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
You can use 3M spray contact cement on the floor, and the insulation. Stick the insulation to the floor. Then use a floor jack with a piece of plywood on it to hold the belly pan up, and rivet in place.
(No Longer at Inland RV)
Old 09-17-2009, 08:58 PM   #3
gutsgolf's Avatar
Thanks Terry,
I was wondering how that was done.
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
Old 09-17-2009, 09:31 PM   #4
Profile:  , Minnesota
Images: 59
It depends on how much insulation you want. If you want 3" or so you can't use the factory method, that only works for an inch or so draped over the crossmembers.
If you want to get some decent R value and you want to keep the insulation from laying on the bellyskin you can use metal straps to keep the batts an inch or so off the skin. It also helps to keep it from soaking up water.
ID:	87295   Click image for larger version
markdoane is online now   Reply With Quote
Old 09-18-2009, 06:45 AM   #5
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I don't think that will stop water from soaking up over time, as soon as it gets any moisture it will hang down - get an air space - useless!
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Belly Pan insulation Ron Banks Belly Pans & Banana Wraps 1 02-11-2009 10:48 AM
Sorry - restoration on hold krazeekalvin Our Community 5 05-03-2007 11:48 AM
Insulation between floor and belly pan. What to use? 68Glbtrotter Repairing/Replacing Floor &/or Frame 17 09-18-2006 09:46 AM
Hold the pickle…… azflycaster Airstream Trailer Forums 9 06-13-2005 07:37 PM
Hold down for Rock Guard uwe Rock Guards, Segment & Window Protectors 5 04-24-2003 06:01 PM
