Old 03-09-2013, 04:01 PM   #1
Vince & Virginia
Towster's Avatar
1969 21' Globetrotter
Riverside , California
What is it called . . .
This is where the A frame attaches to the belly pan. On my '69, they are plastic and cracking. Are there replacements available?
Virginia (SoCal Silver Sister)
"The Towster" 1969 Globetrotter 21' (Silver)
"The Yeti" 2001 Chevy Silverado 2500HD 8.1 Allison Crew Cab (White)
"The Boat" Old Town Canoe Discovery 174 (Green)
Towster is offline   Reply With Quote
Old 03-09-2013, 05:22 PM   #2
cameront120's Avatar
1972 25' Tradewind
I don't know the correct name for it here, but on a building I'd call it flashing. Try contacting Andy at Inland RV, I'm sure he'll be able to give you the correct name and part number.
North Vancouver, BC
Old 03-11-2013, 09:10 PM   #3
Vince & Virginia
Towster's Avatar
Yeah, I guess it would be considered a kind of flashing. It's weird, there's not a consistent rivet pattern attaching it, nor any visible sealant around the edges.
Old 03-11-2013, 09:24 PM   #4
Attachment 180595
Unfortunately, Airstream discontinued that part many years ago.
Take those parts off, then lay a nice bead of Vulkem sealer to seal the gap between the banana wraps and the A-frame.
Andy 14.1
Old 03-11-2013, 10:35 PM   #5
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
Penetration flashing
I do architectural sheet metal and I call that a penetration flashing. What I would do is just make those out of aluminum or stainless steel. The only difference that I see is that the molded flange out to the frame would have to be eliminated. A curved piece of metal notched for the frame would be easy to fabricate. A few rivets and some caulk and your done. If you don't want to rivet into the banana wrap you could weld a couple of tabs to the frame to rivet to but if you did this I would go with "stainless steel".
altnbndr is offline   Reply With Quote
