Old 02-06-2013, 04:19 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Water Tank belly pan removal
After many years of owning Airstream Motorhomes, I got my first Trailer. Its a 1993 34' Limited and i need to get the belly pan off to get to the fresh water tank. What is the safest way to jack the trailer up high enough to drop that pan cover. I do have 4 Jack stands and all the equipment, just not sure how to start. Any suggestion and guidance is appreciated.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 02-06-2013, 04:27 PM   #2
Place the jacks on the "axle mounting plates" ONLY.
Then jack the trailer up as high as you wish.
Or, an easier and safer way is make a ramp for the tires out of some 2 X 6's.
Then wind won't be a factor, and you will have plenty of room.
Old 02-07-2013, 05:07 AM   #3
Airstream Driver
1997 30' Excella
Images: 51
Whats spooks me is the thickness of the Trailer frame and trusting it to support raising and lowering so much weight. The manual says to look for a label that points to plate rivetted to the main frame where the jack head must be placed. I have not found such a label or plate .
1996 Airstream B190
AIR #13
Old 02-07-2013, 05:59 AM   #4
Riverrat6270's Avatar
1980 31' Excella II
Springfield , Illinois
Follow Andy's advice. I would recommend building ramps out of 2 x 6's rather than use jacks. Did my water tank on my Excella with jacks and was rather crowded under there. Good luck
Riverrat6270 is offline   Reply With Quote
Old 02-07-2013, 06:04 AM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Peter,
I would say you need at least six jack stands. That is a very long and heavy trailer to put all that weight on a few square inches of the axle mount plates/frame. The "JACK" label is usually riveted on the belly pan where the main frame rail and an outrigger join about 12"-24" behind the rear axle. Be careful and good luck.
Lance
Top is offline   Reply With Quote
Old 02-07-2013, 08:29 AM   #6
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
I would use the jack stands to catch the holding tank pan as well...it is pretty heavy and maneuvering it and lowering it can be a task for one person without trying to damage it
Protohyp is offline   Reply With Quote
Old 02-07-2013, 09:26 AM   #7
Peter.
The axle mounting plates "always" supports the entire trailer weight, since that's where the tires are.
The stickers your looking for are for "stabilizing jacks ONLY". They are not to be used for lifting.
We raise 34 foot trailers from the axle mounting plates all the time. Never any hint of any type damage.
But, using 2 x 6's as ramps, totally eliminates any lifting of any sorts.
Or, you can always dig a ditch as use it as a pit, and pull the trailer over the pit.
Old 02-07-2013, 08:17 PM   #8
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by Inland RV Center, In View Post
Peter.
Thanks everyone!!
Ok Andy, I'll be right on it.
In the meantime, I followed everyone's advice and pulled her up on some boards. Before dropping the pan, I removed a 6"x6" inspection Plate and found a leaking drain plug. And amazingly enough, it was the plug itself that has hairlines cracks and not the thread or the drain. Now I need to find a 1 3/4 plug that matches this one.
1996 Airstream B190
AIR #13
Old 02-07-2013, 11:37 PM   #9
1981 31' Excella II
New Market , Alabama
I had the same problem with that plug. I made the mistake of removing it. It was a pain to get it to seal again. Those marks are mold marks. Wrap it with several layers of Teflon tape, the thick stuff if you can find it. Make real sure it does not cross thread. Liquid teflon won't work. I had to put mine in tighter than it was originally to get it to seal. The problem is the polyethylene tank stretches over time and the plug loosens up. You could also put a hose clamp around the flange to help reduce the stretch.
Perry
Old 02-08-2013, 04:32 AM   #10
Airstream Driver
1997 30' Excella
Images: 51
Perry
Yes, Perry, one would think its the thread.
Tried several layers of teflon tape, still leaked. The cracks I am talking about are not the mold marks you see. I put water in the hex opening and placed the plug on some paper and it leaked. The more I pushed down on it the more it leaked. Some light behind it revealed hairline cracks, with the main culprit starting in the corner of the recessed hex opening as seen from the back.
1996 Airstream B190
AIR #13
Old 02-08-2013, 04:45 AM   #11
1981 31' Excella II
It should be a standard PVC pipe plug but finding a zero length one is the hard part. Try mcmaster.com.
Perry
Old 02-08-2013, 05:22 AM   #12
Airstream Driver
1997 30' Excella
Images: 51
Perry
Thanks for the link. They have all sizes except 1 3/4" , figures..
1996 Airstream B190
AIR #13
Old 02-08-2013, 07:03 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Ahh Peter...so it begins. Its all good. My trailer is a lot smaller, but I also use the ramp method when working under it and pulling off a wheel or two. Works well. Best of luck with the big boy.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-08-2013, 07:43 AM   #14
1980 31' Excella II
Also, watch the wires on the tank monitor system. I found that they get pinched putting tank bank in with cover. I would suggest cut long so they can be spliced from the top side. Not a tough job just take a little patience.
