Old 08-27-2006, 08:45 PM   #1
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Water draining from the belly pan
I did the first adjustment of my brakes today, just like the book said (maybe a little late but at least I did it) After jacking the street side up, I hear the unmistakable sound of water dripping. Look around and I have several strong drips from the pan on the curb side. I let it empty itself then turned on the water pump, no immediate cycling and no drips. Fill up the shower/tub, pull the plug, no drips. I still need to check the drainage on the kitchen and bath sinks to rule them out.
The trailer has not been pulled in the rain but did get rained on several times before I could rent a covered storage unit. Been about 3 weeks since it was last rained on. Have not seen any sign of water inside.
Still under warranty but I would like to have an idea of where the leak is or what the problem is before I take it to the dealer (125 miles away). If it is simple, I will fix it myself. Short of spraying water on sections of the trailer and testing the remaining drains, are there other things I can do to zero in on the problem?
Greg
Roadtoaster is offline   Reply With Quote
Old 08-27-2006, 10:37 PM   #2
2002 19' Bambi
Lafayette , California
Perhaps our experience might help. A few months after purchase and after use in rain, we noticed similar drainage from the belly pan of our 2002 19' Bambi. We had absolutely no signs of leaks in tanks or anywhere else. Since the belly pan has a few ripples in it, I drilled some small drain holes in the lowest parts of the pan. Water poured out of them. There has been no similar collection of water since and the only leak in the trailer we have ever had came from a cracked air conditioner cover.
Apparently, since the belly pan is not intended to be watertight, the water penetrated along the belly pan seams either while standing or while driving and accumulated in those low spots in the pan. Being thoroughly closed in, the water did not quickly evaporate. We have since assumed that the few small drain holes let any entering water drain right back out, so we no longer have the accumulations.
Tim A. is offline   Reply With Quote
Old 08-28-2006, 12:54 AM   #3
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Hello,
I do know know about the newer trailers... but the older ones had quite a bit of insulation above the bellypan. It is similar to the fluffy fiberglass (typical) home insulation. When it gets wet it becomes saturated.... like a diaper. (That's what my husband calls the area, Airstream diapers....) it can sit in there for lengthy periods of time because of slow (or no) evaporation. Might cause big trouble! Mold on the underneath side of the floor, eventually leading to wood rot.
My suggestion if it is under warranty, have it fixed and don't let the dealer get by with making half hearted attempts!
I would find out what kind of insulation is under there!
Good luck!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 06-24-2015, 10:48 AM   #4
2007 25' International CCD
Lexington , Kentucky
I have 2007 International with the same problem. Mine appears rain related so caulking should help. Do you have any advice?
Jack
jtchinoe is offline   Reply With Quote
Old 06-24-2015, 03:52 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I am not familiar with newer Airstreams. I can tell you on my 86 Limited, and my 66 Trade Wind, rain water pours into the belly pan. The water comes from the rear bumper storage compartment and lid. This is where we store the sewer hose.
I replaced the belly pan and wet fiberglass insulation on both of these trailers. I drilled 1/4" diameter holes in the belly pans of both trailers to help let the water out that does get in there. And I want with rigid foam board insulation that is completely water resistant. Mice don't like it much either.
So maybe your newer trailer has an open bumper storage compartment that allows water into the belly pan area. Something to check out.
David
Old 06-24-2015, 05:09 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I remember my 2001 Safari would drip water from the belly pan after I would wash the trailer. I would notice it coming out as I lowered the hitch jack to get the trailer nose down. I finally figured out it was coming from the rear bumper area. Apparently when using the water sprayer in that area. I know it wasn't accumulating after rain so I just made sure I wasn't spraying that area with a lot of force. That pretty much took are of the issue.
Jack
Jack Canavera
STL Mo.
AIR #56
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 05:18 PM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 10:13 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 02:44 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 05:43 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 03:59 PM
