Old 07-04-2011, 08:14 AM   #1
1994 34' Excella
Greenbank , Washington
Vapor Barrier under trailer
Good Morning!
Our Excella 1000 sits on a large "pad" we made from solid cement blocks.
An airstreamer we know suggested putting a vapor barrier below the trailer, and we have thought about using "Tyvek" or some brand of vapor barrier to do this.
Any thoughts on usig this material, or is there something better? I need something that "breathes."
How would we connect this barrier fabric to the underside of the trailer?
Any ides would be appreciated...
Thanks in advance!
Airy is offline   Reply With Quote
Old 07-04-2011, 08:36 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
The biggest contributor to excess moisture buildup down amongst the nether bits is grass growing up around a parked coach. I sure don't think I'd place any impediment to good air circulation up against the belly wrap. That area is meant to be self draining and, like a good roof, natural ventilation will take care of everything else if you have good flow away of water.
Check out that you have an intact rubrail where the sides meed the belly pan -- especially at the junction with the bumper. Avoid silicone at all costs!
jcanavera was my source on pointing out that long-term parking on concrete draws oils out of tires. Not that tires last much beyond a handful of years anyway. But you might consider rolling your tires onto small rectangles of heavy plastic.
5 meter Langford Nahanni
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
Termites in my Trailer acbolton Winterizing, Storage, Carports & Covers 4 06-09-2011 08:36 AM
Will my trailer get eaten alive now?? mile2885 Cleaning, Stripping & Polishing 12 06-03-2011 05:13 AM
How do you deal with your trailer while exploring? mikescha On The Road... 18 02-21-2011 11:36 AM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
