Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 08-20-2003, 07:27 AM   #1
raebaker06
Profile:  Burlington , Ontario
Underbody repairs
There are several gas lines that are run under the tariler body, and are clamped, But they will vibrate and cause wear.
I put the vinal tubing that you can buy at your local Hdwr store that is used to prevent water dripping on your house water lines. I just slip them one and clamp them with tye wraps.
The body underpanels crack and come loose. the answer is to buy some flashing material from a roofer . Cut to size and pop rivet it on.. BUT FIRST..>>get some washers that have rubber grommets on one side , and it will stop the washers from cutting through the panels.
Rae
raebaker06 is offline   Reply With Quote
Old 08-20-2003, 08:07 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
You can also try these. They are rubber coated and different sizes.
This outfit also sells Olympic rivets and rivet tools.
John
74Argosy24MH is offline   Reply With Quote
Old 08-20-2003, 12:45 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
If you balance the running gear, you don't need to anything to hold the under belly or gas lines in place.
They simply won't vibrate.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Tampa Bay Area Repairs zduke4x The Vendor's Forum 17 11-20-2006 06:41 PM
Zip-Dee Awning Repairs 1985air345 Awnings 3 08-31-2006 06:28 PM
TV antenna repairs lbf78SvgnInt31 Audio, Video & TV 7 07-28-2003 07:02 PM
1978 AS Sovereign and doing my own repairs JLD Our Community 2 09-05-2002 11:28 AM
Transmission repairs rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 08:51 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
