Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 05-25-2004, 05:34 PM   #1
jperryfly
Profile:
Under Panels
Does anyone know what thickness and type aluminum to replace panels underneath trailer with? I was thinking 6061-0 in .025 thickness.
jperryfly is offline   Reply With Quote
Old 05-25-2004, 06:06 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
What year is your trailer?
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
InsideOut is online now   Reply With Quote
Old 05-25-2004, 06:24 PM   #3
jperryfly
Profile:
It's a 31' 1985 Sovereign.
Old 05-26-2004, 05:02 PM   #4
jperryfly
Profile:
Under panels
Did I say something wrong?
Old 05-26-2004, 05:12 PM   #5
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
No, sorry...I just can't help. I only know the vintage stuff...maybe someone else knows or can help.
Shari
Old 05-26-2004, 05:14 PM   #6
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Yes you called them panels rather than belly pan aluminum - just kidding
Anyway - the aluminum used is 2024 T3 - non alclad - if I remember the older trailers used .032 and the newer ones .025.
Ken
1958 Overlander
Ken J is online now   Reply With Quote
Old 05-26-2004, 07:22 PM   #7
jperryfly
Profile:
OK that gives me so good info. I still think I'll use 6061 or 5052 they have much better corrosion resistance than 2024, and they are cheaper too!
Old 05-26-2004, 09:44 PM   #8
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
OK. I'll take the bite What do those numbers mean. And what is the stuff inside.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 05-26-2004, 10:27 PM   #9
jperryfly
Profile:
Those are alloys of aluminum. 5052 is a common commercial grade and 6061-T6 and 2024-T3 are more common to aircraft. The letters and number suffixed are heat treatments. -0 would be annealed or soft no heat treatment. 2024 is much more expensive than 6061, and is normally "alclad" or coated with pure aluminum to resist corrosion. 6061 and 5052 are pretty corrosion resistant already and don't need the alclad. I don't really know all that much about it but you can read more if you get an Aircraft Spruce and Specialty catalogue. The "spruce" in the name came from days when wood was more popular in aircraft building. A 4' x 12' sheet of 6061-T4 .025 thick is $55.50 while the same thing in 2024-T3 is $152. I think 6061 is fine for "belly pans".
Old 05-26-2004, 11:27 PM   #10
greg176
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
Smile
I have read that they only used 2024 on older units.My '61 is all 2024 as evidenced by the severe corrosion in the belly pan and "U" channels.I think that Airstream switched to a commercial grade aluminum in the late sixties,probably a 5000 series.Thanks for the heads up on the price I was getting ready to buy about 12 sheets of 2024 and knew the 5052 was cheaper but never looked.Maybe I'll use 5052 for the belly and interior and will only need 3 sheets of 2024 for sides.
greg176 is offline   Reply With Quote
Old 05-26-2004, 11:31 PM   #11
greg176
greg176's Avatar
Another good source for metal is:
http://www.airpartsinc.com/
Old 05-27-2004, 09:33 AM   #12
jaco
jaco's Avatar
Profile:
Good thread, good information, good to know.
Still would like to know more about the different types of aluminum and their pluses and minuses.
Are there literally thousands of varieties (sure hope not)?
Is alclad coated on both sides? Seems odd that aluminum sheeting would need to be coated with aluminum.. I wonder how that coating is done? Must be applied after the original sheet is completed? No?
Anyone know if the Spruce Co. Catalog is online (PDF maybe) by any chance?
Just interested now in the aluminum sheeting explanation page/s.
jaco is offline   Reply With Quote
Old 05-27-2004, 11:22 AM   #13
greg176
greg176's Avatar
Here is the link to aircraftspruce aluminum info page.
http://www.aircraftspruce.com/catalo...s/aluminfo.php
Yes alclad is coated on both sides and the coating is only about 7 mil thick.The copper in 2024 gives it it's high strength but makes it VERY susceptible to corrosion so it is coated with pure aluminum to protect it.If the alclad is scratched the aloy is exposed an will corrode.
I have not seen a definate answer as to what aluminum was used on later Airstreams but suspect they are made of 5052.
Old 05-27-2004, 11:39 AM   #14
Ken J
Hmmmm, learning something here - so what is the difference between the 5000 and 6000 series - sounds like it would be better for the belly. I assume you can get it in the same thicknesses as 2024 and I assume that its as easy to work with??
Ken
1958 Overlander
stripping the interior panels nevisstudio Upholstery, Blinds, Walls & Interior Finishes 10 03-02-2004 11:51 AM
Interior sliding screen panels Bill McNamara Airstream Motorhome Forums 8 01-30-2004 04:44 PM
Argosy Replacement Panels woody_strohm Ribs, Skins & Rivets 4 09-03-2003 07:39 PM
refrigerator panels eraffety Airstream Motorhome Forums 2 04-01-2002 12:20 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 08:47 AM
