Old 07-15-2014, 08:59 AM   #1
Dustycowgirl's Avatar
1968 26' Overlander
Ocean isle beach , North Carolina
Trying to get belly pan off stuck... Help
I am trying to remove the banana wrap and then get the belly pan off to take a look at the frame. I got the front two pieces of banana stuff off pretty easy but the back left and right side are giving me trouble.... Not sure what to do. It looks like the 68 overlander back curved under. Pieces have a couple buck rivets as well?
Dustycowgirl is offline   Reply With Quote
Old 07-15-2014, 09:35 AM   #2
DFlores's Avatar
1968 22' Safari
Do you have pictures?
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-15-2014, 09:48 AM   #3
DFlores's Avatar
1968 22' Safari
My 68 has a fold over onto the channel, that can only be accessed by removing the shell or the interior skins.
Not sure if yours is built like this, but it would make it difficult to remove for sure.
DFlores
David & Diana
Old 07-15-2014, 09:57 AM   #4
1968 26' Overlander
I'm not sure either I had no problem with the front two piecesClick image for larger version
Name:	ImageUploadedByAirstream Forums1405439813.910914.jpg
ID:	216402 but the back two are stuck
Old 07-15-2014, 10:03 AM   #5
1968 26' Overlander
Also the frame has spray insulation only year they did that and I think that will make painting it/restoring it more difficult
Old 07-15-2014, 10:05 AM   #6
DFlores's Avatar
1968 22' Safari
Built just like mine in front, they slide right out because they are not wrapped over the channel.
DFlores
David & Diana
Old 07-15-2014, 10:08 AM   #7
1968 26' Overlander
So the back two corners should come out the same way correct? Did yours?
Old 07-15-2014, 10:12 AM   #8
DFlores's Avatar
1968 22' Safari
Yes, removing the sprayed insulation is quite a chore, but it gets better.
DFlores
David & Diana
Old 07-15-2014, 10:13 AM   #9
1968 26' Overlander
Name:	ImageUploadedByAirstream Forums1405440764.902459.jpg
Here's a pic of the back side piece it appears to be the top part right where it attaches that it's stuck
Old 07-15-2014, 10:15 AM   #10
DFlores's Avatar
1968 22' Safari
The back corner had to be unfolded. Mine folded over the channel.
Mine were riveted again under the outer shell, not accessible from where you are at this point.
DFlores
David & Diana
Old 07-15-2014, 10:17 AM   #11
DFlores's Avatar
1968 22' Safari
Attachment 216404
In your picture, see the small cuts in the aluminum as it goes under skin, those are the slices that create the lips that fold over the channel. See the first picture that I posted
DFlores
David & Diana
Old 07-15-2014, 10:21 AM   #12
1968 26' Overlander
I see now. Thanks for the help. What would you suggest now? I'm thinking about going in from the floor down in the back bathroom. I would like to take the subfloor out in pieces from the inside and kinda shim up the edges of shell a little at a time w same sized plywood.
Old 07-15-2014, 10:26 AM   #13
DFlores's Avatar
1968 22' Safari
How much of the bathroom is still in the trailer?
DFlores
David & Diana
Old 07-15-2014, 10:30 AM   #14
DFlores's Avatar
1968 22' Safari
Sorry, as I type this stuff, I think of something else.
Does your belly pan have seams that run in a sort of "L" shape forward of these rear pieces? If so, you can remove rivets from that seam and remove most of belly pan that way
DFlores
David & Diana
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Trying to deal with belly pan replacement perryg114 Belly Pans & Banana Wraps 10 09-23-2011 06:45 PM
Belly pan completely off......???? gutsgolf Belly Pans & Banana Wraps 33 10-28-2009 02:25 AM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
